Jackba |
Newbie ![]() Group: Members Posts: 40 Joined: 13-July 18 From: Sacramento Member No.: 22,308 Region Association: Northern California ![]() |
I originally started this as a “Won’t Start” thread and got a ton of help from the group. Prior to not starting at all I had a problem with bucking at all times, not just when warm.
The process of fixing the no start issue was lengthy and included the following: Ultrasonically cleaned all parts of the distributor and oiled the plates Changed condenser Checked points and gap Checked trigger points Checked power to injectors using a noid light Verified normal spray pattern of injectors Checked CHT resistance Removed fuel tank and cleaned sock Verified hoses were not kinked Replaced fuel filter replaced bad relay board Verified operation of relays Checked fuel pressure. Removed and cleaned FI grounds Checked static timing Cleaned near new TPS Replaced fuel pump Replacing the pump fixed the no start problem. Took the car for a quick drive and all was fine. Decided to install a Pertronix ignition module and change ignition wires at the same time. Car is running a 5 year old Beru blue 3.3 ohm coil. Thinking I had everything solved I took the car out for an extended drive last Sunday. For the first 5 miles it ran absolutely great. Better than ever. Then it started hesitating and the hesitation got worse. It started bucking to a point where I didn’t think I could make it home, but I did. Now I’m wondering what else I can possibly do? Any suggestions would be welcome. Thanks, Jack |
rjames |
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,328 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest ![]() ![]() |
The only time my car ever experienced bucking was when i has an intermittent issue with the relay that was being used for the fuel pump. Swapping it out for another relay fixed the issue.
You said you’ve already checked the board and relays, but it still could be fuel related. It would be helpful if you could determine what the fuel pressure was when it starts bucking to rule out any fuel delivery issues before the injectors. |
Lo-Fi Version | Time is now: 1st August 2025 - 10:09 AM |
