| larss |
Jul 9 2019, 01:30 PM
Member ![]() ![]() Group: Members Posts: 434 Joined: 10-September 09 From: Sweden Member No.: 10,787 Region Association: Scandinavia |
Have some problems with a stock 1,7 D-jet that runs wery lean, hunts and pops in the intake, hardly running at all....reving up wery uneven and slowly.
-Engine has not been running for severeal years so there is no history to tell. -Timing triple checked 27 degrees at 3500rpm -Fuel pressure triple checked 31psi -All 4 injectors new (repro) -Trigger points checked OK -Changed to anoter MPS (which runs well in another d-jet) with no difference -Changed head temp sensor with no difference -Compression tested, even around 145psi -Points, condenser, cap, cables are new (also tested with an old set but no difference) -All injectors getting pulses, checked and injector plugs are at the correct injectors -Yes firing order is triple checked The only way to get it running quite OK is to replace the head temp sensor with a potentiometer at 3Kohms, runs quite good with that even when warm. This leads me to think that it is running w e r y lean for some reason. Any ideas? /Lars S |
| larss |
Sep 16 2019, 09:37 AM
Final update - short story:
I had a long sitting 1,7 D-jet with new set of (FR114) injectors started and it ran very very lean...when I changed to a set of Bosch injectors it ran great so i suspected the new injectors to be faulty. However it turned ot that the new injectors only were clogged, probably by old dirt the in car fuel lines (rest of the fuel system is new/cleaned). After ultra sonic cleaning of the new injectors the 1,7 runs great an I have no reason to doubt the function and quality of the FR114 injectors! (IMG:style_emoticons/default/smile.gif) //Lars S |
larss Stock D-jet 1,7 running wery lean but why? S O L V E D Jul 9 2019, 01:30 PM
JeffBowlsby Which MPS part number do you have, does it hold va... Jul 9 2019, 01:32 PM
larss
Which MPS part number do you have, does it hold v... Jul 9 2019, 10:51 PM
BillC Have you checked for a vacuum leak (or leaks)? Si... Jul 10 2019, 10:21 AM
larss
Have you checked for a vacuum leak (or leaks)? S... Jul 10 2019, 10:45 AM
larss Short work on the engine today again...
Found out ... Jul 11 2019, 08:57 AM
JeffBowlsby Besides the lean condition, are your distributor w... Jul 11 2019, 09:32 AM
larss
Besides the lean condition, are your distributor ... Jul 11 2019, 09:50 AM
JeffBowlsby I was not asking about your ignition timing settin... Jul 11 2019, 10:07 AM
larss
I was not asking about your ignition timing setti... Jul 11 2019, 10:27 AM
larss A late update on this....wow finally the car is ru... Aug 25 2019, 08:24 AM![]() ![]() |
Lo-Fi Version | Time is now: 15th April 2026 - 05:20 PM |
