Feeling rich? One for the FI guys! |
Rod |
Sep 16 2019, 03:24 PM
Senior Member Group: Members Posts: 616 Joined: 1-January 08 From: Farnham UK Member No.: 8,526 Region Association: England |
Hi all, it’s a FI diagnosis I’m after, please help.
1973 1.7L standard FI system. When hot after a long run, I have a really rubbish tick-over and car wants to stall. I thought it would be MPS as mine has already been opened by a PO, but it reads 94 ohms on the outer coils and 398ohms on the inner terminals. It seems to hold vacuum too (only tried sucking on it, don’t have a gauge) so can I rule that out?? I really want some further checks to do as it’s running so rich I can see smoke at a hot idle and it’s difficult getting it to pull away without bogging down (only when hot - it’s great when cold!!) So it’s a hot only problem I’m having. Thanks for any help. |
dr914@autoatlanta.com |
Sep 17 2019, 09:51 AM
914 Guru Group: Members Posts: 7,893 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
if you cannot figure it out, you can call me and I will work you through it. If the car was running fine until you added the pertronix, that unit could have failed too, other than that, like previously stated:
head temp sensor fuel pressure manifold pressure sensor leaking vacuum line going to the manifold pressure sensor sticking cold start valve (rare) other things: bad valve adjust causing low compression pertronix disfunctioning bad gas |
Lo-Fi Version | Time is now: 6th June 2024 - 09:19 AM |
