| ThinAir |
Sep 17 2019, 07:12 PM
Best friends ![]() ![]() ![]() ![]() Group: Members Posts: 2,576 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region
Trying to get my car on the road for Red Rock Classic. It's not looking good.
I had an intermittent problem with the fuel pump not running, which at the moment seems to be no longer intermittent. I've successfully tested the pump by connecting it to a battery charger. I've followed the steps in the two fuel pump diagnostic documents at Jeff Bowlsby's site (http://bowlsby.net/914/Classic/zTN_FI_FPChecklist.pdf and http://bowlsby.net/914/Classic/zTN_FI_FPChecklist2.pdf). They both fail at the point where it says I should wrap a wire around pin 87 and reinsert the relay. I get no power on the wire. Following the steps in the Brad Anders document, I don't have 12V on pin 86 and when I test pin 8 on the plug I have power so that means I have a faulty relay board trace. My board was rebuilt last year by a member here who has a great reputation so I don't have any reason to doubt my relay board. I have also tested with 2 other relay boards as well as multiple relays - all with the same result. It just doesn't make sense to me that 3 boards could all have the same issue. I'm stumped. Can anyone provide some additional things to check? |
| ThinAir |
Sep 18 2019, 03:46 PM
(IMG:style_emoticons/default/driving.gif) WooHoo!!!!
Just got back from and extensive test drive. Everything worked wonderfully. I haven't been able to drive this car since March. To hear again the note of the exhaust and the rumble of the engine behind me was wonderful. Feeling the acceleration and taking curves at speed - WOW. I'd forgotten just how sweet this is. Red Rock Classic 2019 - here we come! |
ThinAir Fuel Pump Troubleshooting Sep 17 2019, 07:12 PM
TravisNeff I would also suspect the relay board. When you tu... Sep 17 2019, 07:26 PM
Spoke You can isolate the fuel pump drive circuitry from... Sep 17 2019, 08:44 PM
ThinAir Thanks, Spoke. I'll give that a try in the mor... Sep 17 2019, 11:50 PM
ThinAir Grounding pin III does indeed cause the pump to ru... Sep 18 2019, 12:53 PM
rhodyguy Can you use the carb jumper wire trick to power th... Sep 18 2019, 12:58 PM
ThinAir
Can you use the carb jumper wire trick to power t... Sep 18 2019, 01:06 PM
SirAndy Can you use the carb jumper wire trick to power th... Sep 18 2019, 01:09 PM
SirAndy Is your fuel pump fuse OK? (91) in the pic below.
... Sep 18 2019, 01:12 PM
ThinAir
Is your fuel pump fuse OK? (91) in the pic below.... Sep 18 2019, 01:22 PM
dr914@autoatlanta.com no all three cannot be bad and relay boards rarely... Sep 18 2019, 01:40 PM
ThinAir It works again!
After reviewing the diagram, ... Sep 18 2019, 01:40 PM
Spoke
It works again!...I'm thinking that I jus... Sep 18 2019, 07:25 PM
SirAndy Red Rock Classic 2019 - here we come!
Pack sp... Sep 18 2019, 04:52 PM
jim_hoyland A spare pump is cheap insurance... :) Sep 18 2019, 04:33 PM![]() ![]() |
Lo-Fi Version | Time is now: 22nd September 2026 - 10:55 AM |
