> Fuel Tank cleaning
Rusty
post Sep 23 2019, 07:20 AM
I've got minor surface rust on the interior of my fuel tank. Since I'm pulling the tank out for other maintenance, I might as well handle this too.
Any thoughts on the best way to handle this job? I know there is some controversy about the Eastwood/POR kits.
thanks,
Rusty
ConeDodger
post Sep 23 2019, 07:39 AM
Apex killer!
I used the POR kit with good result. I suspect the people who didn’t get as good a result didn’t follow the instructions to the letter? I did get burned by one of the chemicals when my duct tape improvised tank seals got leaky during the sloshing. The inside of my tank is pristine silver finish. I did mine at least a decade ago.
Rusty   Fuel Tank cleaning   Sep 23 2019, 07:20 AM
ConeDodger   I used the POR kit with good result. I suspect the...   Sep 23 2019, 07:39 AM
BeatNavy   I used the POR kit with good result. I suspect th...   Sep 23 2019, 10:06 AM
mepstein   I used the POR kit with good result. I suspect t...   Sep 23 2019, 10:31 AM
BeatNavy   [quote name='BeatNavy' post='2749526' date='Sep 2...   Sep 23 2019, 01:20 PM
Rusty   Thanks for the advice, Rob. Chemical burns? Yike...   Sep 23 2019, 07:42 AM
ConeDodger   Thanks for the advice, Rob. Chemical burns? Yik...   Sep 23 2019, 08:00 AM
Jamie   Thanks for the advice, Rob. Chemical burns? Yik...   Sep 23 2019, 09:28 AM
Highland   Thanks for the advice, Rob. Chemical burns? Yi...   Sep 24 2019, 08:35 AM
Jamie   [quote name='Jamie' post='2749516' date='Sep 23 2...   Sep 24 2019, 09:36 AM
surfdogskier   I've got minor surface rust on the interior o...   Sep 23 2019, 07:44 AM
914werke   If its truly surface & you want to DIY simply ...   Sep 23 2019, 09:59 AM
mepstein   If its truly surface & you want to DIY simply...   Sep 23 2019, 10:05 AM
VaccaRabite   When you slosh the tanks around, add some roofing ...   Sep 23 2019, 10:26 AM
worn   When you slosh the tanks around, add some roofing...   Sep 23 2019, 11:12 AM
ConeDodger   [quote name='VaccaRabite' post='2749529' date='Se...   Sep 23 2019, 04:38 PM
worn   I like the evapo rust. But it works better warm a...   Sep 23 2019, 04:42 PM
bdstone914   @[url=http://www.914world.com/bbs2/index.php?showu...   Sep 23 2019, 11:28 AM
bdstone914   @[url=http://www.914world.com/bbs2/index.php?showu...   Sep 23 2019, 11:29 AM
Rusty   @bdstone914 Did you use a sealer after?   Sep 23 2019, 12:14 PM
bdstone914   @Rusty no sealer. original tanks did not have any...   Sep 23 2019, 04:06 PM
Rand   Wow this was a hard thread when you could just cle...   Sep 23 2019, 12:17 PM
dr914@autoatlanta.com   the por cleaner works very well we just do not coa...   Sep 23 2019, 04:07 PM
914sgofast2   Rusty: The best and most economical way is to go t...   Sep 24 2019, 04:02 PM
IronHillRestorations   I used to have a small coffee can with KEPS nuts, ...   Sep 24 2019, 11:05 PM
- Lo-Fi Version Time is now: 15th July 2025 - 11:08 AM
