> Axle angle
partwerks
post Sep 8 2019, 05:21 PM
From my trans to my wheels, my axles go uphill at a 10 degree slope. Is that too much?
They angle forward a bit also, but it don't appear to be that much.
euro911
post Sep 23 2019, 01:56 PM
The stance (ride height) of your car looks fine. I'd look into the original thought of raising the transaxle up a couple inches.
partwerks
post Sep 23 2019, 07:18 PM
QUOTE(euro911 @ Sep 23 2019, 11:56 AM) *
The back is 1" lower than the front, and that was measuring to the bottom of the fender lip.
There is room above the trans, but the top/back part of the engine is close to the back of the engine bay, or where the front of the trunk area would be. I think I might have a bit more room to move the engine ahead, and then I would probably have more clearance to move everything up together.
I was told: It is a little low. Those are Bilstein and they seldom go bad. New springs may be in order.
partwerks   Axle angle   Sep 8 2019, 05:21 PM
bdstone914   That rear end must be sitting very low. Badly gagg...   Sep 9 2019, 05:31 AM
914Sixer   Looks like aftermarket springs with spacer blocks.   Sep 9 2019, 05:56 AM
wndsrfr   Looks like aftermarket springs with spacer blocks...   Sep 9 2019, 06:35 AM
partwerks   So maybe need new springs?   Sep 9 2019, 06:04 AM
bdstone914   Hard to say. How does the car sit ? Cant see th...   Sep 9 2019, 06:34 AM
Andyrew   Can we see some pics of your trans mount and the s...   Sep 9 2019, 09:17 AM
SirAndy   Actually looks like the transmission is much lower...   Sep 9 2019, 10:16 AM
Andyrew   Ya I think the trans is falling off the hangers. P...   Sep 9 2019, 10:19 AM
partwerks   Maintenace guy at work, and I made a new trans mou...   Sep 9 2019, 05:23 PM
SirAndy   Your transmission should be a good 2" higher ...   Sep 9 2019, 05:29 PM
partwerks   Your transmission should be a good 2" higher...   Sep 10 2019, 06:06 PM
partwerks   Your transmission should be a good 2" higher...   Sep 11 2019, 08:30 PM
SirAndy   Also, why are your adjustable shocks all the way u...   Sep 9 2019, 05:32 PM
partwerks   Also, why are your adjustable shocks all the way ...   Sep 9 2019, 05:36 PM
SirAndy   Also, why are your adjustable shocks all the way...   Sep 9 2019, 06:21 PM
partwerks   [quote name='partwerks' post='2745633' date='Sep ...   Sep 9 2019, 07:14 PM
BIGKAT_83   Its going to be real low when those rear mounts pu...   Sep 9 2019, 07:22 PM
partwerks   Its going to be real low when those rear mounts p...   Sep 9 2019, 07:27 PM
BIGKAT_83   This is what you need on the top of mount. This ...   Sep 9 2019, 08:03 PM
partwerks   This is what you need on the top of mount. Do...   Sep 9 2019, 08:07 PM
Andyrew   This is what you need on the top of mount. D...   Sep 10 2019, 07:53 PM
euro911   [quote name='partwerks' post='2745686' date='Sep 9...   Sep 23 2019, 09:15 PM
partwerks   [quote name='partwerks' post='2745686' date='Sep ...   Sep 23 2019, 09:53 PM
partwerks   [quote name='partwerks' post='2745686' date='Sep ...   Sep 24 2019, 07:15 PM
euro911   This is what it should look like http://www.914wo...   Sep 10 2019, 08:35 PM
euro911   I just noticed you're not running a 901 trans ...   Sep 11 2019, 11:09 PM
partwerks   I wonder if the adapter plate could be made with a...   Sep 12 2019, 06:05 AM
Andyrew   I wonder if the adapter plate could be made with ...   Sep 12 2019, 09:02 AM
euro911   I wonder if the adapter plate could be made with a...   Sep 13 2019, 12:40 PM
euro911   From my trans to my wheels, my axles go uphill at ...   Sep 12 2019, 01:57 PM
partwerks   From my trans to my wheels, my axles go uphill at...   Sep 13 2019, 08:51 AM
partwerks   Looks like at the top of that adapter plate...   Sep 13 2019, 01:35 PM
partwerks   These shocks and springs are at least 13 years old...   Sep 13 2019, 07:34 PM
Andyrew   These shocks and springs are at least 13 years ol...   Sep 13 2019, 07:42 PM
partwerks   These shocks and springs are at least 13 years o...   Sep 13 2019, 07:53 PM
partwerks   RE: Axle angle   Sep 15 2019, 05:47 PM
Andyrew   It's low but I've seen lower. I say modify...   Sep 15 2019, 08:15 PM
Krieger   I love that color!   Sep 16 2019, 08:20 AM
partwerks   I love that color! Thanks. It was originall...   Sep 16 2019, 06:20 PM
76-914   You can pick up another 2" if you delete the ...   Sep 16 2019, 09:20 AM
partwerks   Will putting on new springs help with the angle on...   Sep 23 2019, 05:43 AM
Andyrew   Will putting on new springs help with the angle o...   Sep 23 2019, 07:38 AM
euro911   The stance (ride height) of your car looks fine. I...   Sep 23 2019, 01:56 PM
partwerks   The stance (ride height) of your car looks fine. ...   Sep 23 2019, 07:18 PM
euro911   Certain things need to be identified. Is it an al...   Sep 25 2019, 05:16 PM
partwerks   Got it on the hoist, for a few better pictures. ...   Sep 25 2019, 06:44 PM
euro911   Can you shorten the upright sections of the trans ...   Sep 25 2019, 07:51 PM
partwerks   Can you shorten the upright sections of the trans...   Sep 25 2019, 08:12 PM
partwerks   Can you shorten the upright sections of the trans...   Sep 27 2019, 09:07 PM
euro911   Can you shorten the upright sections of the trans ...   Sep 28 2019, 03:59 AM
partwerks   [quote name='partwerks' post='2750756' date='Sep ...   Sep 28 2019, 08:11 AM
euro911   Not sure how heavy of springs are in there, but wo...   Sep 28 2019, 11:50 AM
ClayPerrine   [quote name='euro911' post='2750189' date='Sep 25...   Sep 28 2019, 08:04 PM
Mike Bellis   Based on what I see, you have a compound angle lik...   Sep 27 2019, 10:33 PM
partwerks   Based on what I see, you have a compound angle li...   Sep 27 2019, 10:39 PM
Mike Bellis   Drive it a few hundred miles and check to see if t...   Sep 27 2019, 10:41 PM
euro911   Wow, well thought-out design, Clay. :first:   Sep 29 2019, 02:57 PM
jimkelly   enjoyed your pics. thanks.   Oct 5 2019, 07:10 PM
- Lo-Fi Version Time is now: 10th November 2026 - 01:23 AM
