> Fuel Tank cleaning
Rusty
post Sep 23 2019, 07:20 AM
I've got minor surface rust on the interior of my fuel tank. Since I'm pulling the tank out for other maintenance, I might as well handle this too.
Any thoughts on the best way to handle this job? I know there is some controversy about the Eastwood/POR kits.
thanks,
Rusty
914sgofast2
post Sep 24 2019, 04:02 PM
Rusty:
The best and most economical way is to go to your local grocery store or Costco and buy 6 gallons of white distilled vinegar. Then go to your Home Depot, Lowe's, or ACE Hardware and buy two plumber's test expanding rubber tipped plugs: one for the big hole for the gas tank filler neck and a smaller one for the gas tank sending unit hole. Alternatively, you can leave the sending unit in the tank with no ill effects. Leave/put back all the small threaded bolts that hold down the filler pipe and the gauge sending unit screwed into the tank to seal up the small mounting holes.
Next just put a length of fuel line hose to connect the two bottom tank outlets; or, as I did, remove both of the the outlet pipes and connect a piece of old heater hose (either 5/8" or 3/4" inside diameter - I can't remember) from one threaded outlet to the other on the bottom of the tank.
Pour all the distilled vinegar into the tank and replace the plumber's test plug. Let the tank sit on its side for a day. Next day turn the tank over so the vinegar can cover the other inside half of the tank.
On the third day, drain out the vinegar and refill the tank with a combination of water and a box or two of Arm and Hammer Baking Soda to neutralize the acid. Let the baking soda and water sit in the tank for a couple of hours, then drain it out and flush the tank with water to rinse it all out.
Then dry out the inside of the tank using a hair dryer pointed into one or both of the big holes.
Once the inside of the tank is dry, pour a quart of Automatic Transmission Fluid into the tank and slosh it all around to prevent "flash rusting". When you are ready to put the tank back into the car, turn the tank upright and drain out the ATF and put the tank back into car and fill it with gas.
You will be amazed at how this cleans out all the rust. I learned this from watching YouTube videos on how to clean motorcycle gas tanks and used it on my 914's tank a year ago. It worked perfectly. No need to worry about disposing of hazardous chemicals or breathing dangerous vapors from the various snake oil products sold by Eastwood, Por15 or others looking to empty your wallet. No need to use expensive gas tank coatings of dubious effectiveness on the inside of the tank.
Mike D.
Rusty   Fuel Tank cleaning   Sep 23 2019, 07:20 AM
ConeDodger   I used the POR kit with good result. I suspect the...   Sep 23 2019, 07:39 AM
BeatNavy   I used the POR kit with good result. I suspect th...   Sep 23 2019, 10:06 AM
mepstein   I used the POR kit with good result. I suspect t...   Sep 23 2019, 10:31 AM
BeatNavy   [quote name='BeatNavy' post='2749526' date='Sep 2...   Sep 23 2019, 01:20 PM
Rusty   Thanks for the advice, Rob. Chemical burns? Yike...   Sep 23 2019, 07:42 AM
ConeDodger   Thanks for the advice, Rob. Chemical burns? Yik...   Sep 23 2019, 08:00 AM
Jamie   Thanks for the advice, Rob. Chemical burns? Yik...   Sep 23 2019, 09:28 AM
Highland   Thanks for the advice, Rob. Chemical burns? Yi...   Sep 24 2019, 08:35 AM
Jamie   [quote name='Jamie' post='2749516' date='Sep 23 2...   Sep 24 2019, 09:36 AM
surfdogskier   I've got minor surface rust on the interior o...   Sep 23 2019, 07:44 AM
914werke   If its truly surface & you want to DIY simply ...   Sep 23 2019, 09:59 AM
mepstein   If its truly surface & you want to DIY simply...   Sep 23 2019, 10:05 AM
VaccaRabite   When you slosh the tanks around, add some roofing ...   Sep 23 2019, 10:26 AM
worn   When you slosh the tanks around, add some roofing...   Sep 23 2019, 11:12 AM
ConeDodger   [quote name='VaccaRabite' post='2749529' date='Se...   Sep 23 2019, 04:38 PM
worn   I like the evapo rust. But it works better warm a...   Sep 23 2019, 04:42 PM
bdstone914   @[url=http://www.914world.com/bbs2/index.php?showu...   Sep 23 2019, 11:28 AM
bdstone914   @[url=http://www.914world.com/bbs2/index.php?showu...   Sep 23 2019, 11:29 AM
Rusty   @bdstone914 Did you use a sealer after?   Sep 23 2019, 12:14 PM
bdstone914   @Rusty no sealer. original tanks did not have any...   Sep 23 2019, 04:06 PM
Rand   Wow this was a hard thread when you could just cle...   Sep 23 2019, 12:17 PM
dr914@autoatlanta.com   the por cleaner works very well we just do not coa...   Sep 23 2019, 04:07 PM
914sgofast2   Rusty: The best and most economical way is to go t...   Sep 24 2019, 04:02 PM
IronHillRestorations   I used to have a small coffee can with KEPS nuts, ...   Sep 24 2019, 11:05 PM
- Lo-Fi Version Time is now: 15th July 2025 - 11:23 AM
