> Axle angle
partwerks
post Sep 8 2019, 05:21 PM
From my trans to my wheels, my axles go uphill at a 10 degree slope. Is that too much?
They angle forward a bit also, but it don't appear to be that much.
Mike Bellis
post Sep 27 2019, 10:33 PM
Resident Electrician
Based on what I see, you have a compound angle like I had. With my Boxster tranny my axle stubbs would "walk" out after 150 miles. The car would have no forward or reverse motion until the stub was hammered back into the tranny.
The stubs are held in with a $1 circlip (Porsche Dealer). They did not have enough tension to hold back against the tug from the suspension movement. You can try an O ring, thin one under the circlip.
In my case I realigned the the drivertrain to shift everything forward until it aligned straight but remained lowered. No more problems.
Not sure which Boxster tranny you have or if your stubs are held in the same. Unbolt the CV and see if there is a big bolt head under it. If not, yours are held in by the same circlip.
partwerks
post Sep 27 2019, 10:39 PM
QUOTE(Mike Bellis @ Sep 27 2019, 08:33 PM) *
I have the 5 speed Boxster trans.
He had the custom axles and parts made at driveshaftshop.com
partwerks   Axle angle   Sep 8 2019, 05:21 PM
bdstone914   That rear end must be sitting very low. Badly gagg...   Sep 9 2019, 05:31 AM
914Sixer   Looks like aftermarket springs with spacer blocks.   Sep 9 2019, 05:56 AM
wndsrfr   Looks like aftermarket springs with spacer blocks...   Sep 9 2019, 06:35 AM
partwerks   So maybe need new springs?   Sep 9 2019, 06:04 AM
bdstone914   Hard to say. How does the car sit ? Cant see th...   Sep 9 2019, 06:34 AM
Andyrew   Can we see some pics of your trans mount and the s...   Sep 9 2019, 09:17 AM
SirAndy   Actually looks like the transmission is much lower...   Sep 9 2019, 10:16 AM
Andyrew   Ya I think the trans is falling off the hangers. P...   Sep 9 2019, 10:19 AM
partwerks   Maintenace guy at work, and I made a new trans mou...   Sep 9 2019, 05:23 PM
SirAndy   Your transmission should be a good 2" higher ...   Sep 9 2019, 05:29 PM
partwerks   Your transmission should be a good 2" higher...   Sep 10 2019, 06:06 PM
partwerks   Your transmission should be a good 2" higher...   Sep 11 2019, 08:30 PM
SirAndy   Also, why are your adjustable shocks all the way u...   Sep 9 2019, 05:32 PM
partwerks   Also, why are your adjustable shocks all the way ...   Sep 9 2019, 05:36 PM
SirAndy   Also, why are your adjustable shocks all the way...   Sep 9 2019, 06:21 PM
partwerks   [quote name='partwerks' post='2745633' date='Sep ...   Sep 9 2019, 07:14 PM
BIGKAT_83   Its going to be real low when those rear mounts pu...   Sep 9 2019, 07:22 PM
partwerks   Its going to be real low when those rear mounts p...   Sep 9 2019, 07:27 PM
BIGKAT_83   This is what you need on the top of mount. This ...   Sep 9 2019, 08:03 PM
partwerks   This is what you need on the top of mount. Do...   Sep 9 2019, 08:07 PM
Andyrew   This is what you need on the top of mount. D...   Sep 10 2019, 07:53 PM
euro911   [quote name='partwerks' post='2745686' date='Sep 9...   Sep 23 2019, 09:15 PM
partwerks   [quote name='partwerks' post='2745686' date='Sep ...   Sep 23 2019, 09:53 PM
partwerks   [quote name='partwerks' post='2745686' date='Sep ...   Sep 24 2019, 07:15 PM
euro911   This is what it should look like http://www.914wo...   Sep 10 2019, 08:35 PM
euro911   I just noticed you're not running a 901 trans ...   Sep 11 2019, 11:09 PM
partwerks   I wonder if the adapter plate could be made with a...   Sep 12 2019, 06:05 AM
Andyrew   I wonder if the adapter plate could be made with ...   Sep 12 2019, 09:02 AM
euro911   I wonder if the adapter plate could be made with a...   Sep 13 2019, 12:40 PM
euro911   From my trans to my wheels, my axles go uphill at ...   Sep 12 2019, 01:57 PM
partwerks   From my trans to my wheels, my axles go uphill at...   Sep 13 2019, 08:51 AM
partwerks   Looks like at the top of that adapter plate...   Sep 13 2019, 01:35 PM
partwerks   These shocks and springs are at least 13 years old...   Sep 13 2019, 07:34 PM
Andyrew   These shocks and springs are at least 13 years ol...   Sep 13 2019, 07:42 PM
partwerks   These shocks and springs are at least 13 years o...   Sep 13 2019, 07:53 PM
partwerks   RE: Axle angle   Sep 15 2019, 05:47 PM
Andyrew   It's low but I've seen lower. I say modify...   Sep 15 2019, 08:15 PM
Krieger   I love that color!   Sep 16 2019, 08:20 AM
partwerks   I love that color! Thanks. It was originall...   Sep 16 2019, 06:20 PM
76-914   You can pick up another 2" if you delete the ...   Sep 16 2019, 09:20 AM
partwerks   Will putting on new springs help with the angle on...   Sep 23 2019, 05:43 AM
Andyrew   Will putting on new springs help with the angle o...   Sep 23 2019, 07:38 AM
euro911   The stance (ride height) of your car looks fine. I...   Sep 23 2019, 01:56 PM
partwerks   The stance (ride height) of your car looks fine. ...   Sep 23 2019, 07:18 PM
euro911   Certain things need to be identified. Is it an al...   Sep 25 2019, 05:16 PM
partwerks   Got it on the hoist, for a few better pictures. ...   Sep 25 2019, 06:44 PM
euro911   Can you shorten the upright sections of the trans ...   Sep 25 2019, 07:51 PM
partwerks   Can you shorten the upright sections of the trans...   Sep 25 2019, 08:12 PM
partwerks   Can you shorten the upright sections of the trans...   Sep 27 2019, 09:07 PM
euro911   Can you shorten the upright sections of the trans ...   Sep 28 2019, 03:59 AM
partwerks   [quote name='partwerks' post='2750756' date='Sep ...   Sep 28 2019, 08:11 AM
euro911   Not sure how heavy of springs are in there, but wo...   Sep 28 2019, 11:50 AM
ClayPerrine   [quote name='euro911' post='2750189' date='Sep 25...   Sep 28 2019, 08:04 PM
Mike Bellis   Based on what I see, you have a compound angle lik...   Sep 27 2019, 10:33 PM
partwerks   Based on what I see, you have a compound angle li...   Sep 27 2019, 10:39 PM
Mike Bellis   Drive it a few hundred miles and check to see if t...   Sep 27 2019, 10:41 PM
euro911   Wow, well thought-out design, Clay. :first:   Sep 29 2019, 02:57 PM
jimkelly   enjoyed your pics. thanks.   Oct 5 2019, 07:10 PM
- Lo-Fi Version Time is now: 10th November 2026 - 01:23 AM
