> Axle angle
partwerks
post Sep 8 2019, 05:21 PM
From my trans to my wheels, my axles go uphill at a 10 degree slope. Is that too much?
They angle forward a bit also, but it don't appear to be that much.
euro911
post Sep 25 2019, 07:51 PM
Can you shorten the upright sections of the trans mount to gain a couple inches of upward movement?
partwerks
post Sep 27 2019, 09:07 PM
QUOTE(euro911 @ Sep 25 2019, 05:51 PM) *
Are you saying to cut the flat bars loose on top of the main bracket, and jack the trans up higher, and then reweld the flat bars?
euro911
post Sep 28 2019, 03:59 AM
QUOTE(partwerks @ Sep 27 2019, 08:07 PM) *
In looking at how high the transaxle already sits in the bracket, it appears that it may not be possible to section it. You'll need to take the stock upper washer plates into consideration too - (I think they're approx 1/2" thick). If those rubber mounts crack and fail and you don't have those plates in place, your transaxle could fall.
I'm also wondering if a different rubber mount could be fabricated, and located UNDER the 'flat bars' (instead of above)? ... looks like you could gain an inch or so there (IMG:style_emoticons/default/idea.gif)
If you're planning on raising the rear suspension (as you mentioned earlier) with taller springs, you'll gain even more equality between the center-line of the trans output shafts and the center-line at the wheel hubs. That should straighten out the axle angles enough to cause a lot less wear & tear on the CVs.
partwerks
post Sep 28 2019, 08:11 AM
QUOTE(euro911 @ Sep 28 2019, 01:59 AM) *
Not sure how heavy of springs are in there, but wonder how heavy I need for the LS3 engine, 180lb?
Sounds like 180lb are shorter than stock?
https://forums.pelicanparts.com/porsche-914...ed-details.html
I have the mounting plates on top now.
I'm not sure how I could move the trans forward any?
partwerks   Axle angle   Sep 8 2019, 05:21 PM
bdstone914   That rear end must be sitting very low. Badly gagg...   Sep 9 2019, 05:31 AM
914Sixer   Looks like aftermarket springs with spacer blocks.   Sep 9 2019, 05:56 AM
wndsrfr   Looks like aftermarket springs with spacer blocks...   Sep 9 2019, 06:35 AM
partwerks   So maybe need new springs?   Sep 9 2019, 06:04 AM
bdstone914   Hard to say. How does the car sit ? Cant see th...   Sep 9 2019, 06:34 AM
Andyrew   Can we see some pics of your trans mount and the s...   Sep 9 2019, 09:17 AM
SirAndy   Actually looks like the transmission is much lower...   Sep 9 2019, 10:16 AM
Andyrew   Ya I think the trans is falling off the hangers. P...   Sep 9 2019, 10:19 AM
partwerks   Maintenace guy at work, and I made a new trans mou...   Sep 9 2019, 05:23 PM
SirAndy   Your transmission should be a good 2" higher ...   Sep 9 2019, 05:29 PM
partwerks   Your transmission should be a good 2" higher...   Sep 10 2019, 06:06 PM
partwerks   Your transmission should be a good 2" higher...   Sep 11 2019, 08:30 PM
SirAndy   Also, why are your adjustable shocks all the way u...   Sep 9 2019, 05:32 PM
partwerks   Also, why are your adjustable shocks all the way ...   Sep 9 2019, 05:36 PM
SirAndy   Also, why are your adjustable shocks all the way...   Sep 9 2019, 06:21 PM
partwerks   [quote name='partwerks' post='2745633' date='Sep ...   Sep 9 2019, 07:14 PM
BIGKAT_83   Its going to be real low when those rear mounts pu...   Sep 9 2019, 07:22 PM
partwerks   Its going to be real low when those rear mounts p...   Sep 9 2019, 07:27 PM
BIGKAT_83   This is what you need on the top of mount. This ...   Sep 9 2019, 08:03 PM
partwerks   This is what you need on the top of mount. Do...   Sep 9 2019, 08:07 PM
Andyrew   This is what you need on the top of mount. D...   Sep 10 2019, 07:53 PM
euro911   [quote name='partwerks' post='2745686' date='Sep 9...   Sep 23 2019, 09:15 PM
partwerks   [quote name='partwerks' post='2745686' date='Sep ...   Sep 23 2019, 09:53 PM
partwerks   [quote name='partwerks' post='2745686' date='Sep ...   Sep 24 2019, 07:15 PM
euro911   This is what it should look like http://www.914wo...   Sep 10 2019, 08:35 PM
euro911   I just noticed you're not running a 901 trans ...   Sep 11 2019, 11:09 PM
partwerks   I wonder if the adapter plate could be made with a...   Sep 12 2019, 06:05 AM
Andyrew   I wonder if the adapter plate could be made with ...   Sep 12 2019, 09:02 AM
euro911   I wonder if the adapter plate could be made with a...   Sep 13 2019, 12:40 PM
euro911   From my trans to my wheels, my axles go uphill at ...   Sep 12 2019, 01:57 PM
partwerks   From my trans to my wheels, my axles go uphill at...   Sep 13 2019, 08:51 AM
partwerks   Looks like at the top of that adapter plate...   Sep 13 2019, 01:35 PM
partwerks   These shocks and springs are at least 13 years old...   Sep 13 2019, 07:34 PM
Andyrew   These shocks and springs are at least 13 years ol...   Sep 13 2019, 07:42 PM
partwerks   These shocks and springs are at least 13 years o...   Sep 13 2019, 07:53 PM
partwerks   RE: Axle angle   Sep 15 2019, 05:47 PM
Andyrew   It's low but I've seen lower. I say modify...   Sep 15 2019, 08:15 PM
Krieger   I love that color!   Sep 16 2019, 08:20 AM
partwerks   I love that color! Thanks. It was originall...   Sep 16 2019, 06:20 PM
76-914   You can pick up another 2" if you delete the ...   Sep 16 2019, 09:20 AM
partwerks   Will putting on new springs help with the angle on...   Sep 23 2019, 05:43 AM
Andyrew   Will putting on new springs help with the angle o...   Sep 23 2019, 07:38 AM
euro911   The stance (ride height) of your car looks fine. I...   Sep 23 2019, 01:56 PM
partwerks   The stance (ride height) of your car looks fine. ...   Sep 23 2019, 07:18 PM
euro911   Certain things need to be identified. Is it an al...   Sep 25 2019, 05:16 PM
partwerks   Got it on the hoist, for a few better pictures. ...   Sep 25 2019, 06:44 PM
euro911   Can you shorten the upright sections of the trans ...   Sep 25 2019, 07:51 PM
partwerks   Can you shorten the upright sections of the trans...   Sep 25 2019, 08:12 PM
partwerks   Can you shorten the upright sections of the trans...   Sep 27 2019, 09:07 PM
euro911   Can you shorten the upright sections of the trans ...   Sep 28 2019, 03:59 AM
partwerks   [quote name='partwerks' post='2750756' date='Sep ...   Sep 28 2019, 08:11 AM
euro911   Not sure how heavy of springs are in there, but wo...   Sep 28 2019, 11:50 AM
ClayPerrine   [quote name='euro911' post='2750189' date='Sep 25...   Sep 28 2019, 08:04 PM
Mike Bellis   Based on what I see, you have a compound angle lik...   Sep 27 2019, 10:33 PM
partwerks   Based on what I see, you have a compound angle li...   Sep 27 2019, 10:39 PM
Mike Bellis   Drive it a few hundred miles and check to see if t...   Sep 27 2019, 10:41 PM
euro911   Wow, well thought-out design, Clay. :first:   Sep 29 2019, 02:57 PM
jimkelly   enjoyed your pics. thanks.   Oct 5 2019, 07:10 PM
- Lo-Fi Version Time is now: 10th November 2026 - 01:23 AM
