watsonrx13 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States ![]() |
I've begun my fuel delivery upgrade with the removal of the fuel tank. Everything went as planned until I needed to remove the tank from the car. The article, from PP, suggested that I lift the passenger side and cut the fuel lines at the bottom of the tank. I was unable to lift the tank high enough on the passenger side, but I was able to lift it on the drivers side (the rubber lines were about 4" long). The only way I was able to cut the lines was with a hacksaw blade. After removing the tank from the car, the next problem I ran into was removing the metal fuel lines from the bottom on the tank.
After removing the large nut, how do I remove the line (see attached pic)? Do I need to keep the larger line (3/8") or the smaller line (5/16") if I'm running dual webers? Attached image(s) ![]() |
Zeke |
Never left, but not right.... ![]() ![]() Group: Members Posts: 392 Joined: 26-January 03 From: Long Beach CA Member No.: 197 Region Association: None ![]() |
When switching to carbs, I left the smalller return line and installed a short hose and a petcock to drain the tank if I want to. I ran Aeroquip push on hose from the bigger line a few inches to a truck brake line. That's 3/8ths steel. It wont rub thru from vibration. At least not as fast as aluminum. Easy to push thru the tunnel. Once in the engine bay, I went back to Areoquip to the filter, then the pump, next the regulator and then the tee.
Lo-Fi Version | Time is now: 11th July 2025 - 03:30 AM |
