> Lifts, 2 Post Hydraulic Lift Questions
ctc911ctc
post Feb 14 2019, 11:25 AM
All,
I am rebuilding the garage, very small NE garage 19' x 10' and about 8' clear.
I am thinking about installing a 2 post lift where each post would be against the walls, out of the way.
I am concerned about the safety of these lifts, I would only be putting 914s or 911s on this lift.
1. Is the anchoring of the pad sufficient to keep these from tilting (forward/back)?
2. How deep do the anchors need to be placed into the floor? Very little detail on web sites.
3. Are there any preferences as to vendors? I have been looking at this one:
https://www.toolots.com/two-post-car-lift-l...#productDetails
My requirements are that the lift be as small (footprint) and safe as possible.
THANK YOU ALL TEENERS!
CTC911CTC
Krieger
post Sep 28 2019, 10:43 AM
Now I am considering the move to the two post lift. I have had an EZ car lift for at least 10 years, but I want to stop rolling around on the ground and stand or as close to that as possible. I have a good size garage that is 25'×25' with 10' high ceilings. What are the electrical requirements for these lifts? Is 110 enough?
ClayPerrine
post Sep 28 2019, 08:19 PM
QUOTE(Krieger @ Sep 28 2019, 11:43 AM) *
Every two post lift I have ever seen requires 220V ac to work. Have an electrician wire up a new circuit from your breaker panel to the lift.
ctc911ctc   Lifts   Feb 14 2019, 11:25 AM
BPic   I have this one: https://www.maxjaxusa.com/buy-pu...   Feb 14 2019, 11:32 AM
mepstein   The lift should have specific installation instruc...   Feb 14 2019, 12:14 PM
ClayPerrine   You are not going to get most two post lifts under...   Feb 14 2019, 12:59 PM
ctc911ctc   Not going to happen, brick carriage house, rebuild...   Feb 14 2019, 01:02 PM
ClayPerrine   They make a few short versions of the two post lif...   Feb 14 2019, 04:00 PM
jvmarino   Max Jax is pretty much your only option. That is w...   Feb 14 2019, 07:18 PM
wndsnd   I agree Max Jack is fantastic at that ceiling heig...   Feb 14 2019, 07:35 PM
mepstein   I agree Max Jack is fantastic at that ceiling hei...   Feb 14 2019, 08:47 PM
rgolia   I agree Max Jack is fantastic at that ceiling hei...   Feb 15 2019, 09:53 AM
cuddy_k   Quick Jack is another great option. The lift secti...   Feb 15 2019, 06:25 AM
mb911   Quick Jack is another great option. The lift sect...   Feb 17 2019, 09:28 AM
ctc911ctc   On my list - went to buy it today - price raised t...   Apr 3 2019, 08:10 AM
mgphoto   I decided on the EZ Car lift, light weight, very p...   Feb 15 2019, 08:47 AM
ctc911ctc   After carefully considering what was posted, my li...   Feb 15 2019, 10:22 AM
John   Each of the two Rotary lifts (7,000# and 10,000#) ...   Feb 15 2019, 12:45 PM
Chi-town   If you can't go up, what about down? Cut the ...   Feb 15 2019, 02:25 PM
mepstein   If you can't go up, what about down? Cut the...   Feb 15 2019, 02:55 PM
ctc911ctc   Good thing I am an engineer! The concrete is ...   Feb 15 2019, 08:07 PM
sithot   Expensive but possible an option. Might have to ...   Feb 16 2019, 09:37 AM
Mark Henry   There's a one post lift, plus it can be rolled...   Feb 16 2019, 08:47 AM
burton73   There's a one post lift, plus it can be rolle...   Feb 17 2019, 12:20 PM
mepstein   There's a one post lift, plus it can be roll...   Feb 17 2019, 03:27 PM
ledfoot   The Maxjax works with the 3” pad extension for...   Feb 16 2019, 09:58 AM
ctc911ctc   The Maxjax works with the 3” pad extension fo...   Feb 16 2019, 11:56 AM
r_towle   The Maxjax works with the 3” pad extension f...   Feb 17 2019, 03:49 PM
mepstein   [quote name='ctc911ctc' post='2689468' date='Feb ...   Feb 17 2019, 04:02 PM
mb911   [quote name='ctc911ctc' post='2689468' date='Feb...   Feb 17 2019, 04:21 PM
ClayPerrine   [quote name='mepstein' post='2689907' date='Feb 1...   Feb 18 2019, 07:10 AM
mepstein   [quote name='mepstein' post='2689907' date='Feb ...   Feb 18 2019, 07:18 AM
ClayPerrine   [quote name='ClayPerrine' post='2690041' date='Fe...   Feb 19 2019, 06:52 AM
Mark Henry   [quote name='ClayPerrine' post='2690041' date='Fe...   Feb 20 2019, 02:37 PM
mepstein   [quote name='ClayPerrine' post='2690041' date='F...   Feb 20 2019, 02:44 PM
ClayPerrine   [quote name='Mark Henry' post='2690809' date='Feb...   Feb 21 2019, 02:45 PM
sithot   Bendpak: https://www.bendpak.com/grandprix/   Feb 23 2019, 09:07 AM
steuspeed   Single side option. https://aclifts.com/lifts/m-...   Feb 17 2019, 03:43 PM
AHudson   Quick Jack is another great option. The lift sect...   Feb 18 2019, 07:57 AM
mepstein   Any lift is better than jack stands.   Feb 18 2019, 08:01 AM
North Coast Jim   All, I am rebuilding the garage, very small NE g...   Feb 18 2019, 11:19 AM
Triaddave   If the ceiling is the limit on going up, build a p...   Feb 18 2019, 12:41 PM
mepstein   If the ceiling is the limit on going up, build a ...   Feb 18 2019, 01:31 PM
cuddy_k   Maxjax is a great option if you like/need to work ...   Feb 18 2019, 01:30 PM
dan10101   When I turned 50 I petitioned for a rack. I chose...   Feb 19 2019, 09:22 PM
ctc911ctc   When I turned 50 I petitioned for a rack. I chos...   Feb 20 2019, 12:16 PM
TheWeatherMan   When I turned 50 I petitioned for a rack. I chos...   Feb 26 2019, 02:11 PM
dr914@autoatlanta.com   after looking at many many many lifts and lift man...   Feb 23 2019, 09:51 AM
sithot   after looking at many many many lifts and lift ma...   Feb 23 2019, 10:34 AM
mb911   Just bought a maxjax for 1500 today delivered.. Wa...   Feb 26 2019, 05:31 PM
mepstein   Just bought a maxjax for 1500 today delivered.. W...   Feb 26 2019, 05:34 PM
DRPHIL914   Just bought a maxjax for 1500 today delivered.. W...   Feb 27 2019, 08:19 AM
mb911   Just bought a maxjax for 1500 today delivered.. ...   Feb 27 2019, 11:18 AM
Freezin 914   As some of you know, I just bought a mid rise lift...   Feb 26 2019, 06:14 PM
Mark Henry   One thing I don't like about some of the sciss...   Feb 27 2019, 06:07 AM
Carl La Fong   Mid size lifts are great. This garage has a 7 fo...   Apr 3 2019, 10:15 AM
rhodyguy   Welcome back Elliot! You've been missed ...   Apr 3 2019, 11:22 AM
76-914   Welcome back Elliot! You've been missed ...   Apr 3 2019, 12:52 PM
Carl La Fong   Welcome back Elliot! You've been missed ...   Apr 3 2019, 02:46 PM
Mark Henry   Welcome back Elliot! You've been missed ...   Apr 3 2019, 02:54 PM
Krieger   Welcome back Elliot! You've been missed ...   Apr 3 2019, 10:41 PM
rhodyguy   Man...that's a lot of quotes. Quote happy Wedn...   Apr 3 2019, 01:01 PM
Carl La Fong   I have no idea who you are all talking about.   Apr 3 2019, 02:48 PM
sb914   I have no idea who you are all talking about. I ...   Apr 3 2019, 04:29 PM
Hans Zupp   I have no idea who you are all talking about.I do...   Apr 25 2019, 09:34 AM
914-300Hemi   I just placed an order for a MaxJax 2 post lift. L...   Apr 3 2019, 09:41 PM
mb911   I just placed an order for a MaxJax 2 post lift. ...   Apr 4 2019, 05:46 AM
76-914   I'm lucky there. My hose slips into the recess...   Apr 4 2019, 08:34 AM
mlindner   Ben, just get a cement blade for your circular saw...   Apr 4 2019, 12:15 PM
914_teener   Ben, just get a cement blade for your circular sa...   Apr 4 2019, 12:24 PM
mepstein   Hose Protector Ramp - sold on Amazon   Apr 4 2019, 12:26 PM
mlindner   Ben, found a better shot before I filled the grove...   Apr 4 2019, 12:26 PM
mlindner   914 teener. Bendpak, 6,000 lbs. love it.   Apr 4 2019, 12:29 PM
mlindner   ctc911ctc, just looking at your garage size again....   Apr 4 2019, 01:11 PM
914_teener   ctc911ctc, just looking at your garage size again...   Apr 4 2019, 03:26 PM
Mark Henry   ctc911ctc, just looking at your garage size agai...   Apr 5 2019, 06:10 AM
mlindner   Just noticed, two out of the three two post lifts ...   Apr 4 2019, 01:29 PM
mb911   @mlinder I suppose I could do that.. Not a bad id...   Apr 4 2019, 03:08 PM
Dredwin   I embraced my hose...bought a pool noodle, cut it ...   Apr 4 2019, 03:50 PM
mlindner   914 teener, good question and I do have a Cayman.....   Apr 5 2019, 05:12 AM
mlindner   I agree Mark, with doing that much work...trans, e...   Apr 5 2019, 07:01 AM
Krieger   Now I am considering the move to the two post lift...   Sep 28 2019, 10:43 AM
ClayPerrine   Now I am considering the move to the two post lif...   Sep 28 2019, 08:19 PM
914-d   One of the lifts I have is 110v, the other is 220v...   Sep 28 2019, 10:58 AM
mb911   The maxjax works on 110 .. I have used all kinds a...   Sep 28 2019, 08:32 PM
oldschool   I got this off of crags list its a tire chief has...   Sep 29 2019, 01:07 AM
sithot   A friend has put these in his latest dealership. ...   Sep 29 2019, 05:39 AM
ClayPerrine   FWIW: It's apparently a little known fact t...   Sep 29 2019, 12:21 PM
mb911   I need one that is about 48" might have to ma...   Sep 29 2019, 12:52 PM
sithot   I need one that is about 48" might have to m...   Sep 29 2019, 03:23 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:02 PM
