Carbs and fuel pump relay, my solution |
hcdmueller |
Feb 2 2009, 03:27 PM
????????????? Group: Members Posts: 542 Joined: 4-February 06 From: UK Member No.: 5,527 Region Association: England |
I am running carbs on my 2056 so I performed the simple mod as described by SirAndy in the Tech Articles. One thing I have noticed with my car is that my fuel pump runs continuously with the key switched on. The fuel pump is a rotary one that I bought from the Type4Store.
I didn't like that fact that my pump kept running so I took matters into my own hands. I modified a Bosch CIS fuel pump relay to work with my car. It needs a signal from the negative side of the coil to provide power to the fuel pump. So unless the engine is cranking or running it won't start up the pump. Nice to have the extra safety margin as well. The relays are easy to find in the junk yard. I only paid a couple dollars for 3 of them. Attached image(s) |
Ansbacher |
Sep 28 2019, 04:28 PM
Senior Member Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
The Revolution thingy looks OK but a 3 second prime for carbs is no where near enough down here in hot Florida. The 356 I used to have and my present 914 with carbs always require(d) about 10 seconds of prime. If that thing was adjustable I would consider it.
Ansbacher |
DickSteinkamp |
Sep 28 2019, 04:29 PM
Senior Member Group: Members Posts: 500 Joined: 27-February 17 From: Bellingham, WA Member No.: 20,876 Region Association: None |
The Revolution thingy looks OK but a 3 second prime for carbs is no where near enough down here in hot Florida. The 356 I used to have and my present 914 with carbs always require(d) about 10 seconds of prime. If that thing was adjustable I would consider it. Ansbacher I think you would just need to turn the key on and off and on a few times. |
Ansbacher |
Sep 29 2019, 11:05 AM
QUOTE I think you would just need to turn the key on and off and on a few times. That means to get at LEAST ten seconds of prime I would have turn my key four times. Sounds like a lot of unnecessary wear and tear on a switch that fails often. |
porschetub |
Sep 29 2019, 01:42 PM
Advanced Member Group: Members Posts: 4,705 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
QUOTE I think you would just need to turn the key on and off and on a few times. That means to get at LEAST ten seconds of prime I would have turn my key four times. Sounds like a lot of unnecessary wear and tear on a switch that fails often. (IMG:style_emoticons/default/agree.gif) and it would be a bit of a pain,IMO 3 seconds wouldn't even get a six on carbs started,when my car has sat for a while the bowls were dry,thought I had a hard start problem till I found this out when the car was first put in storage. I do think it is a great safety device however,didn't someone mention an oil pressure sender that turns off the pump when the oil pressure drops to a low set point or none @all ?. |
Lo-Fi Version | Time is now: 8th June 2024 - 12:27 AM |
