| Ecoleft |
Sep 29 2019, 03:24 PM
Newbie ![]() Group: Members Posts: 21 Joined: 21-September 19 From: Tehachapi Member No.: 23,485 Region Association: Central California |
I'm looking for an ECU to go on a 1975 1.8 engine. However when I look for a computer theres about 100 different numbers and letters with it and I have no idea how to check with computer will work with my engine. I have two possible computers to use and they both end with a different letter. I have no idea how to tell which one needs to go on my car. The next question would then be what jets do I need. I have two different type of jets. An I jet and an L jet.
| DickSteinkamp |
Sep 30 2019, 09:47 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 500 Joined: 27-February 17 From: Bellingham, WA Member No.: 20,876 Region Association: None |
The next question would then be what jets do I need. I have two different type of jets. An I jet and an L jet. Not sure what you need. I've never heard of an I Jet, but L Jet is short for the Bosch L Jetronic Fuel Injection system which your 75 1.8 should be equipped with. L=German for luft (air). The ECU (engine control unit) is a part of this system. |
Ecoleft Ecu computer problems Sep 29 2019, 03:24 PM
JeffBowlsby 280 000 104 = CU65X = 1974 1.8L
280 000 111 = CU66... Sep 29 2019, 03:37 PM
Ecoleft
280 000 111 = CU6... Oct 2 2019, 12:55 PM
Ecoleft
[quote name='JeffBowlsby' post='27511... Oct 2 2019, 12:56 PM
Ecoleft
[quote name='JeffBowlsby' post='2751... Oct 3 2019, 10:57 AM
dr914@autoatlanta.com and if you are uncertain that the unit is bad, you... Sep 30 2019, 08:43 AM
ClayPerrine The 1970s ECUs are really robust. They don't o... Sep 30 2019, 12:31 PM
Ecoleft
The 1970s ECUs are really robust. They don't ... Oct 2 2019, 12:50 PM
914fahrer your picture shows a ECU from the D-jetronic your ... Oct 2 2019, 01:51 PM
JeffBowlsby The 037 ECU is correct for either a 1973 1.7L or 2... Oct 2 2019, 02:12 PM
Ecoleft
The 037 ECU is correct for either a 1973 1.7L or ... Oct 3 2019, 10:57 AM
DickSteinkamp The ECU you show looks like it has been wet for a ... Oct 2 2019, 03:37 PM
ClayPerrine Do you know if you have an L-Jet system or a D-Jet... Oct 3 2019, 12:46 PM
Ecoleft
Do you know if you have an L-Jet system or a D-Je... Oct 4 2019, 10:30 AM
JeffBowlsby Please be more forthcoming with all details of exa... Oct 4 2019, 10:46 AM
Ecoleft
Please be more forthcoming with all details of ex... Oct 4 2019, 05:22 PM
bdstone914 Yes. You can not hook up an L jet ecu to a D jet h... Oct 4 2019, 05:37 PM
Ecoleft
Yes. You can not hook up an L jet ecu to a D jet ... Oct 4 2019, 06:47 PM
Ecoleft
[quote name='bdstone914' post='2752259' date='Oct... Oct 4 2019, 06:48 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th April 2026 - 12:04 PM |
