| 914CLE |
Oct 2 2019, 03:46 PM
Newbie ![]() Group: Members Posts: 7 Joined: 19-September 19 From: Cleveland Member No.: 23,476 Region Association: Upper MidWest |
So after 22 years in my garage, I can finally get around to restarting. At this point, drained the gas, replaced all fuel line hoses and most vacuum lines, plugs look good, spark looks good, fuel is spraying from all injectors. Adjusted lifters. Car won't start. Any suggestions as to trouble shoot? I've ohm'd out coil (it's fine), voltage to coil is 10V (I think it's enough) as it main supply sparks, all cylinders has sparks. Turns over, no firing. Changed points to Petronix II. Still nothing even with staring fluid ( I would think if it was fuel delivery, it would at least fire for a few seconds with starting fluid).
It ran before I garaged it. Any suggestions, check lists to follow?? Do I need to hook up air filter and vacuum lines to get it to even start at a rough idle? |
| infraredcalvin |
Oct 2 2019, 08:27 PM
Distracted Member ![]() ![]() ![]() Group: Members Posts: 1,770 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California
The fact that starting fluid doesn't at least cough sounds like you're not getting spark when cranking. (IMG:style_emoticons/default/agree.gif) Static timed? Was distributor removed, sure it’s clocked accurately? |
914CLE 22 years later Oct 2 2019, 03:46 PM
Superhawk996 10V to coil is not sufficient unless that 10V was ... Oct 2 2019, 06:17 PM
914CLE
10V to coil is not sufficient unless that 10V was... Oct 3 2019, 12:14 PM
Superhawk996
I have 10V with the ignition on, what could be i... Oct 3 2019, 01:15 PM
dr914@autoatlanta.com before the pertronix, install points and condenser... Oct 3 2019, 07:52 AM
914CLE
before the pertronix, install points and condense... Oct 3 2019, 12:15 PM
cuddy_k
I'm going to check the rest this week, but n... Oct 3 2019, 12:30 PM
ClayPerrine
[quote name='914CLE' post='2751893' date='Oct 3 2... Oct 3 2019, 12:53 PM
914CLE
[quote name='914CLE' post='2751893' date='Oct 3 2... Oct 8 2019, 04:05 PM
914CLE
[quote name='914CLE' post='2751893' date='Oct 3 2... Oct 8 2019, 04:08 PM
Rand All this talk about static timing. When would it h... Oct 3 2019, 05:17 PM
JOEPROPER Spark, fuel and compression are the key ingredient... Oct 3 2019, 05:46 PM
Superhawk996
Spark, fuel and compression are the key ingredien... Oct 3 2019, 06:17 PM
rgalla9146 Did you switch from points to pertronix before att... Oct 4 2019, 08:34 AM
Jacob I cannot give you a definitive answer, just questi... Oct 4 2019, 01:12 PM
ClayPerrine I use the FAST method.
F = Fuel
A = Air (compre... Oct 4 2019, 02:27 PM
914CLE So put new points back in along with cap, rotor, w... Oct 8 2019, 04:30 PM
VaccaRabite
So put new points back in along with cap, rotor, ... Oct 8 2019, 06:46 PM
914CLE
So put new points back in along with cap, rotor,... Oct 8 2019, 09:52 PM![]() ![]() |
Lo-Fi Version | Time is now: 19th September 2026 - 04:50 PM |
