| 914CLE |
Oct 2 2019, 03:46 PM
Newbie ![]() Group: Members Posts: 7 Joined: 19-September 19 From: Cleveland Member No.: 23,476 Region Association: Upper MidWest |
So after 22 years in my garage, I can finally get around to restarting. At this point, drained the gas, replaced all fuel line hoses and most vacuum lines, plugs look good, spark looks good, fuel is spraying from all injectors. Adjusted lifters. Car won't start. Any suggestions as to trouble shoot? I've ohm'd out coil (it's fine), voltage to coil is 10V (I think it's enough) as it main supply sparks, all cylinders has sparks. Turns over, no firing. Changed points to Petronix II. Still nothing even with staring fluid ( I would think if it was fuel delivery, it would at least fire for a few seconds with starting fluid).
It ran before I garaged it. Any suggestions, check lists to follow?? Do I need to hook up air filter and vacuum lines to get it to even start at a rough idle? |
| dr914@autoatlanta.com |
Oct 3 2019, 07:52 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,244 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
before the pertronix, install points and condenser, set the dwell to 50 and statically set the timing. Check the plug for a spark, then remove the air cleaner and while cranking spray the starting fluid into the throttle body (hope that you have previously put marvel mystery oil into the cylinders overnight then turned over to circulate and also changed the oil and cleaned out the strainer)
So after 22 years in my garage, I can finally get around to restarting. At this point, drained the gas, replaced all fuel line hoses and most vacuum lines, plugs look good, spark looks good, fuel is spraying from all injectors. Adjusted lifters. Car won't start. Any suggestions as to trouble shoot? I've ohm'd out coil (it's fine), voltage to coil is 10V (I think it's enough) as it main supply sparks, all cylinders has sparks. Turns over, no firing. Changed points to Petronix II. Still nothing even with staring fluid ( I would think if it was fuel delivery, it would at least fire for a few seconds with starting fluid). It ran before I garaged it. Any suggestions, check lists to follow?? Do I need to hook up air filter and vacuum lines to get it to even start at a rough idle? |
| 914CLE |
Oct 3 2019, 12:15 PM
before the pertronix, install points and condenser, set the dwell to 50 and statically set the timing. Check the plug for a spark, then remove the air cleaner and while cranking spray the starting fluid into the throttle body (hope that you have previously put marvel mystery oil into the cylinders overnight then turned over to circulate and also changed the oil and cleaned out the strainer) Working on this right now before I go any further. So after 22 years in my garage, I can finally get around to restarting. At this point, drained the gas, replaced all fuel line hoses and most vacuum lines, plugs look good, spark looks good, fuel is spraying from all injectors. Adjusted lifters. Car won't start. Any suggestions as to trouble shoot? I've ohm'd out coil (it's fine), voltage to coil is 10V (I think it's enough) as it main supply sparks, all cylinders has sparks. Turns over, no firing. Changed points to Petronix II. Still nothing even with staring fluid ( I would think if it was fuel delivery, it would at least fire for a few seconds with starting fluid). It ran before I garaged it. Any suggestions, check lists to follow?? Do I need to hook up air filter and vacuum lines to get it to even start at a rough idle? |
914CLE 22 years later Oct 2 2019, 03:46 PM
Superhawk996 10V to coil is not sufficient unless that 10V was ... Oct 2 2019, 06:17 PM
914CLE
10V to coil is not sufficient unless that 10V was... Oct 3 2019, 12:14 PM
Superhawk996
I have 10V with the ignition on, what could be i... Oct 3 2019, 01:15 PM
infraredcalvin The fact that starting fluid doesn't at least ... Oct 2 2019, 08:27 PM
cuddy_k
I'm going to check the rest this week, but n... Oct 3 2019, 12:30 PM
ClayPerrine
[quote name='914CLE' post='2751893' date='Oct 3 2... Oct 3 2019, 12:53 PM
914CLE
[quote name='914CLE' post='2751893' date='Oct 3 2... Oct 8 2019, 04:05 PM
914CLE
[quote name='914CLE' post='2751893' date='Oct 3 2... Oct 8 2019, 04:08 PM
Rand All this talk about static timing. When would it h... Oct 3 2019, 05:17 PM
JOEPROPER Spark, fuel and compression are the key ingredient... Oct 3 2019, 05:46 PM
Superhawk996
Spark, fuel and compression are the key ingredien... Oct 3 2019, 06:17 PM
rgalla9146 Did you switch from points to pertronix before att... Oct 4 2019, 08:34 AM
Jacob I cannot give you a definitive answer, just questi... Oct 4 2019, 01:12 PM
ClayPerrine I use the FAST method.
F = Fuel
A = Air (compre... Oct 4 2019, 02:27 PM
914CLE So put new points back in along with cap, rotor, w... Oct 8 2019, 04:30 PM
VaccaRabite
So put new points back in along with cap, rotor, ... Oct 8 2019, 06:46 PM
914CLE
So put new points back in along with cap, rotor,... Oct 8 2019, 09:52 PM![]() ![]() |
Lo-Fi Version | Time is now: 19th September 2026 - 04:50 PM |
