> 22 years later, How to restart after my own garage find. '73 1.7
914CLE
post Oct 2 2019, 03:46 PM
So after 22 years in my garage, I can finally get around to restarting. At this point, drained the gas, replaced all fuel line hoses and most vacuum lines, plugs look good, spark looks good, fuel is spraying from all injectors. Adjusted lifters. Car won't start. Any suggestions as to trouble shoot? I've ohm'd out coil (it's fine), voltage to coil is 10V (I think it's enough) as it main supply sparks, all cylinders has sparks. Turns over, no firing. Changed points to Petronix II. Still nothing even with staring fluid ( I would think if it was fuel delivery, it would at least fire for a few seconds with starting fluid).
It ran before I garaged it.
Any suggestions, check lists to follow??
Do I need to hook up air filter and vacuum lines to get it to even start at a rough idle?
JOEPROPER
post Oct 3 2019, 05:46 PM
The answer is "no" unless you ask...
Spark, fuel and compression are the key ingredients. (IMG:style_emoticons/default/agree.gif) with above, timing is probably not your problem unless you messed with it.
914CLE   22 years later   Oct 2 2019, 03:46 PM
Superhawk996   10V to coil is not sufficient unless that 10V was ...   Oct 2 2019, 06:17 PM
914CLE   10V to coil is not sufficient unless that 10V was...   Oct 3 2019, 12:14 PM
Superhawk996   I have 10V with the ignition on, what could be i...   Oct 3 2019, 01:15 PM
infraredcalvin   The fact that starting fluid doesn't at least ...   Oct 2 2019, 08:27 PM
dr914@autoatlanta.com   before the pertronix, install points and condenser...   Oct 3 2019, 07:52 AM
914CLE   before the pertronix, install points and condense...   Oct 3 2019, 12:15 PM
cuddy_k   I'm going to check the rest this week, but n...   Oct 3 2019, 12:30 PM
ClayPerrine   [quote name='914CLE' post='2751893' date='Oct 3 2...   Oct 3 2019, 12:53 PM
914CLE   [quote name='914CLE' post='2751893' date='Oct 3 2...   Oct 8 2019, 04:05 PM
914CLE   [quote name='914CLE' post='2751893' date='Oct 3 2...   Oct 8 2019, 04:08 PM
Rand   All this talk about static timing. When would it h...   Oct 3 2019, 05:17 PM
JOEPROPER   Spark, fuel and compression are the key ingredient...   Oct 3 2019, 05:46 PM
Superhawk996   Spark, fuel and compression are the key ingredien...   Oct 3 2019, 06:17 PM
rgalla9146   Did you switch from points to pertronix before att...   Oct 4 2019, 08:34 AM
Jacob   I cannot give you a definitive answer, just questi...   Oct 4 2019, 01:12 PM
ClayPerrine   I use the FAST method. F = Fuel A = Air (compre...   Oct 4 2019, 02:27 PM
914CLE   So put new points back in along with cap, rotor, w...   Oct 8 2019, 04:30 PM
VaccaRabite   So put new points back in along with cap, rotor, ...   Oct 8 2019, 06:46 PM
914CLE   So put new points back in along with cap, rotor,...   Oct 8 2019, 09:52 PM
- Lo-Fi Version Time is now: 19th September 2026 - 04:50 PM
