| cpavlenko |
Oct 3 2019, 01:59 PM
Member ![]() ![]() Group: Members Posts: 489 Joined: 19-April 12 From: North Arizona Member No.: 14,400 Region Association: Southwest Region |
I built my 1.7 to a 2.0 with 2 Weber 44s. When I get back from a good cruise and park it in garage, after bout 7 mins later I here a gurgling from the carbs. Fuel dripping on butterfly's. Stinks up my 3 car garage. Me and my mechanic are doing different things. The last thing I tried was pulling a nipple I put on the expansion tank where the charcoal canister line went to the expansion tank. Did another 50 mile cruise, and parked it in the garage and after 7 mins nothing, then a little drip. It was about 3/4 better taking the nipple off. Soooooooooo, what is going on, I'm confused and help would be thankful.
| Superhawk996 |
Oct 3 2019, 03:15 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,772 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
I see you are in AZ. Are you running it hot and then immediately parking it? That could be causing some fuel boiling? Have you tried a few minutes of idle cooling before you shut down to see if that affects it?
Do you have the fuel line entering the carb from above the level of the carb? Sort of sounds like it could also be leaky float needle valves and the fuel is draining into the carb bowl via gravity. High fuel bowl level can then cause a bleed over into the carbs. Fuel line should enter into the carb body from below the carb. Make sure that as your fuel line crosses over from one carb to the other carb, that you aren't routing that crossover line higher than the carb. I've seen people loop it up though the loop for the trunk torsion bars. This puts it higher than the carb and susceptible for gravity drain back if a float needle is worn. |
| cpavlenko |
Oct 3 2019, 07:40 PM
I see you are in AZ. Are you running it hot and then immediately parking it? That could be causing some fuel boiling? Have you tried a few minutes of idle cooling before you shut down to see if that affects it? Do you have the fuel line entering the carb from above the level of the carb? Sort of sounds like it could also be leaky float needle valves and the fuel is draining into the carb bowl via gravity. High fuel bowl level can then cause a bleed over into the carbs. Fuel line should enter into the carb body from below the carb. Make sure that as your fuel line crosses over from one carb to the other carb, that you aren't routing that crossover line higher than the carb. I've seen people loop it up though the loop for the trunk torsion bars. This puts it higher than the carb and susceptible for gravity drain back if a float needle is worn. I'm in Northern Arizona, and it's been in the low to med 70's. |
cpavlenko Carbs Oct 3 2019, 01:59 PM
cpavlenko
I see you are in AZ. Are you running it hot and ... Oct 3 2019, 07:41 PM
cpavlenko
I see you are in AZ. Are you running it hot and... Oct 3 2019, 07:47 PM
cpavlenko
I see you are in AZ. Are you running it hot and ... Oct 3 2019, 08:31 PM
John Do you have any insulators between the heads and t... Oct 3 2019, 03:46 PM
johnhora phenolic spacers between the manifold and carb
ht... Oct 3 2019, 06:08 PM
cpavlenko I've also heard of putting on/off switch for f... Oct 3 2019, 08:09 PM
michael7810
I've also heard of putting on/off switch for ... Oct 4 2019, 10:56 AM
cpavlenko Here's some pictures. 2 pictures show plugged ... Oct 3 2019, 08:44 PM
cpavlenko
Here's some pictures. 2 pictures show plugged... Oct 3 2019, 09:10 PM
cpavlenko
[quote name='cpavlenko' post='2752006' date='Oct ... Oct 3 2019, 09:44 PM
cpavlenko
[quote name='cpavlenko' post='2752017' date='Oct ... Oct 3 2019, 09:48 PM
MikeM Hello...I had the exact same issue with my Weber 4... Oct 4 2019, 09:15 AM
cpavlenko Sorry for the multi post guys. Was doing uploads o... Oct 4 2019, 09:38 AM
Superhawk996 All the fuel line routings look sensible.
The pl... Oct 4 2019, 11:22 AM
cpavlenko Yeah, the gurgling I here must be heat related. Lo... Oct 4 2019, 12:32 PM
yeahmag Stock intake gaskets (which are a spacer of sorts)... Oct 4 2019, 03:34 PM
porschetub Have you tried adjusting the fuel pressure to say ... Oct 5 2019, 01:54 PM
cpavlenko OK, if I put a phenolic spacer between manifold an... Oct 5 2019, 08:50 PM
yeahmag Take the rain tray off. You are fixing the symptom... Oct 5 2019, 09:17 PM
cpavlenko
Take the rain tray off. You are fixing the sympto... Oct 5 2019, 09:48 PM
yeahmag The stock part will for the FI runners should do t... Oct 5 2019, 10:02 PM
MikeM Triangle Auto Supply in Yakima, Washington.... Oct 6 2019, 08:05 AM![]() ![]() |
Lo-Fi Version | Time is now: 9th April 2026 - 12:03 PM |
