> Carbs, Weber 44s
cpavlenko
post Oct 3 2019, 01:59 PM
I built my 1.7 to a 2.0 with 2 Weber 44s. When I get back from a good cruise and park it in garage, after bout 7 mins later I here a gurgling from the carbs. Fuel dripping on butterfly's. Stinks up my 3 car garage. Me and my mechanic are doing different things. The last thing I tried was pulling a nipple I put on the expansion tank where the charcoal canister line went to the expansion tank. Did another 50 mile cruise, and parked it in the garage and after 7 mins nothing, then a little drip. It was about 3/4 better taking the nipple off. Soooooooooo, what is going on, I'm confused and help would be thankful.
cpavlenko
post Oct 3 2019, 08:44 PM
Here's some pictures. 2 pictures show plugged and unplugged on expansion tank. That made it a lot less dripping to butterflies on carbs after a good 50 mile run. The other pics show fuel lines and pressure regulator which is at 3.5 lbs. Attached ImageAttached Image
cpavlenko
post Oct 3 2019, 09:10 PM
QUOTE(cpavlenko @ Oct 3 2019, 07:44 PM) *
More pics.Attached Image
cpavlenko
post Oct 3 2019, 09:44 PM
QUOTE(cpavlenko @ Oct 3 2019, 08:10 PM) *
cpavlenko
post Oct 3 2019, 09:48 PM
QUOTE(cpavlenko @ Oct 3 2019, 08:44 PM) *
cpavlenko   Carbs   Oct 3 2019, 01:59 PM
Superhawk996   I see you are in AZ. Are you running it hot and t...   Oct 3 2019, 03:15 PM
cpavlenko   I see you are in AZ. Are you running it hot and ...   Oct 3 2019, 07:40 PM
cpavlenko   I see you are in AZ. Are you running it hot and ...   Oct 3 2019, 07:41 PM
cpavlenko   I see you are in AZ. Are you running it hot and...   Oct 3 2019, 07:47 PM
cpavlenko   I see you are in AZ. Are you running it hot and ...   Oct 3 2019, 08:31 PM
John   Do you have any insulators between the heads and t...   Oct 3 2019, 03:46 PM
johnhora   phenolic spacers between the manifold and carb ht...   Oct 3 2019, 06:08 PM
cpavlenko   I've also heard of putting on/off switch for f...   Oct 3 2019, 08:09 PM
michael7810   I've also heard of putting on/off switch for ...   Oct 4 2019, 10:56 AM
cpavlenko   Here's some pictures. 2 pictures show plugged ...   Oct 3 2019, 08:44 PM
cpavlenko   Here's some pictures. 2 pictures show plugged...   Oct 3 2019, 09:10 PM
cpavlenko   [quote name='cpavlenko' post='2752006' date='Oct ...   Oct 3 2019, 09:44 PM
cpavlenko   [quote name='cpavlenko' post='2752017' date='Oct ...   Oct 3 2019, 09:48 PM
MikeM   Hello...I had the exact same issue with my Weber 4...   Oct 4 2019, 09:15 AM
cpavlenko   Sorry for the multi post guys. Was doing uploads o...   Oct 4 2019, 09:38 AM
Superhawk996   All the fuel line routings look sensible. The pl...   Oct 4 2019, 11:22 AM
cpavlenko   Yeah, the gurgling I here must be heat related. Lo...   Oct 4 2019, 12:32 PM
yeahmag   Stock intake gaskets (which are a spacer of sorts)...   Oct 4 2019, 03:34 PM
porschetub   Have you tried adjusting the fuel pressure to say ...   Oct 5 2019, 01:54 PM
cpavlenko   OK, if I put a phenolic spacer between manifold an...   Oct 5 2019, 08:50 PM
yeahmag   Take the rain tray off. You are fixing the symptom...   Oct 5 2019, 09:17 PM
cpavlenko   Take the rain tray off. You are fixing the sympto...   Oct 5 2019, 09:48 PM
yeahmag   The stock part will for the FI runners should do t...   Oct 5 2019, 10:02 PM
MikeM   Triangle Auto Supply in Yakima, Washington....   Oct 6 2019, 08:05 AM
- Lo-Fi Version Time is now: 9th April 2026 - 12:01 PM
