| cpavlenko |
Oct 3 2019, 01:59 PM
Member ![]() ![]() Group: Members Posts: 489 Joined: 19-April 12 From: North Arizona Member No.: 14,400 Region Association: Southwest Region |
I built my 1.7 to a 2.0 with 2 Weber 44s. When I get back from a good cruise and park it in garage, after bout 7 mins later I here a gurgling from the carbs. Fuel dripping on butterfly's. Stinks up my 3 car garage. Me and my mechanic are doing different things. The last thing I tried was pulling a nipple I put on the expansion tank where the charcoal canister line went to the expansion tank. Did another 50 mile cruise, and parked it in the garage and after 7 mins nothing, then a little drip. It was about 3/4 better taking the nipple off. Soooooooooo, what is going on, I'm confused and help would be thankful.
| cpavlenko |
Oct 3 2019, 08:09 PM
I've also heard of putting on/off switch for fuel pump. Switching to off before turning power off. In other words turn pump off and wait tell fuel runs out, then power down the 914.
| michael7810 |
Oct 4 2019, 10:56 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,082 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region
I've also heard of putting on/off switch for fuel pump. Switching to off before turning power off. In other words turn pump off and wait tell fuel runs out, then power down the 914. I did this for a similar problem plus to use as a theft deterrent. I have not parked it in the garage since the mod but from what I can tell it helps reduce the fuel smell from the carbs. The other benefit is I can mess with my Bluetooth distributor programming without the fuel pump running while the ignition is on |
cpavlenko Carbs Oct 3 2019, 01:59 PM
Superhawk996 I see you are in AZ. Are you running it hot and t... Oct 3 2019, 03:15 PM
cpavlenko
I see you are in AZ. Are you running it hot and ... Oct 3 2019, 07:40 PM
cpavlenko
I see you are in AZ. Are you running it hot and ... Oct 3 2019, 07:41 PM
cpavlenko
I see you are in AZ. Are you running it hot and... Oct 3 2019, 07:47 PM
cpavlenko
I see you are in AZ. Are you running it hot and ... Oct 3 2019, 08:31 PM
John Do you have any insulators between the heads and t... Oct 3 2019, 03:46 PM
johnhora phenolic spacers between the manifold and carb
ht... Oct 3 2019, 06:08 PM
cpavlenko Here's some pictures. 2 pictures show plugged ... Oct 3 2019, 08:44 PM
cpavlenko
Here's some pictures. 2 pictures show plugged... Oct 3 2019, 09:10 PM
cpavlenko
[quote name='cpavlenko' post='2752006' date='Oct ... Oct 3 2019, 09:44 PM
cpavlenko
[quote name='cpavlenko' post='2752017' date='Oct ... Oct 3 2019, 09:48 PM
MikeM Hello...I had the exact same issue with my Weber 4... Oct 4 2019, 09:15 AM
cpavlenko Sorry for the multi post guys. Was doing uploads o... Oct 4 2019, 09:38 AM
Superhawk996 All the fuel line routings look sensible.
The pl... Oct 4 2019, 11:22 AM
cpavlenko Yeah, the gurgling I here must be heat related. Lo... Oct 4 2019, 12:32 PM
yeahmag Stock intake gaskets (which are a spacer of sorts)... Oct 4 2019, 03:34 PM
porschetub Have you tried adjusting the fuel pressure to say ... Oct 5 2019, 01:54 PM
cpavlenko OK, if I put a phenolic spacer between manifold an... Oct 5 2019, 08:50 PM
yeahmag Take the rain tray off. You are fixing the symptom... Oct 5 2019, 09:17 PM
cpavlenko
Take the rain tray off. You are fixing the sympto... Oct 5 2019, 09:48 PM
yeahmag The stock part will for the FI runners should do t... Oct 5 2019, 10:02 PM
MikeM Triangle Auto Supply in Yakima, Washington.... Oct 6 2019, 08:05 AM![]() ![]() |
Lo-Fi Version | Time is now: 9th April 2026 - 12:06 PM |
