> Boxster "S" 6 speed trans
partwerks
post Oct 5 2019, 02:50 PM
The Boxster "S" 6 speed trans, that is used with the LS3 engine. Are all of the transaxles geared differently, or all the same?
Is anyone else running the Boxster "S" 6 speed, with an LS engine?
tygaboy
post Oct 6 2019, 03:11 PM
Lyle - If you mean the shifter and associated cables, you can get a stock Boxster S shifter and cables on ebay for under $150. Here's one that's available now.
I splurged and got a Numeric shifter and cable set up. Not cheap, but super neat-o!
partwerks
post Oct 6 2019, 05:36 PM
QUOTE(tygaboy @ Oct 6 2019, 01:11 PM) *
I'm guessing the main body of the shifter operates differently than the 6, and needs to be changed along with the cables?
How does the Audi/Passat 6 speed compare to the Boxster, or would that even work?
partwerks   Boxster "S" 6 speed trans   Oct 5 2019, 02:50 PM
tygaboy   The Boxster S trans is the G86-20. All of those ha...   Oct 5 2019, 03:38 PM
partwerks   The Boxster S trans is the G86-20. All of those h...   Oct 13 2019, 03:16 PM
Cracker   Lyle, I replied to your PM...the system is amazin...   Oct 5 2019, 07:21 PM
partwerks   Lyle, I replied to your PM...the system is amazi...   Oct 5 2019, 08:48 PM
ClayPerrine   I have a 2006 Cayman S G86-21 trans in my car. It...   Oct 5 2019, 09:10 PM
partwerks   Any pictures of what trans mount Renegade Hybrids ...   Oct 5 2019, 09:50 PM
Joemo5   Any pictures of what trans mount Renegade Hybrids...   Oct 5 2019, 10:33 PM
Cracker   1) If there IS one downside of the Renegade mount ...   Oct 6 2019, 06:56 AM
tygaboy   I'd bet that Tony has the market cornered on s...   Oct 6 2019, 09:12 AM
Lof8   But so far, so good on the Renegade design. I...   Jul 2 2024, 01:01 PM
dakotaewing   Tony and Clay, What did each of you do to address...   Oct 6 2019, 11:00 AM
Cracker   I have not seen a used box posted for sale that di...   Oct 6 2019, 11:24 AM
tygaboy   Lyle - If you mean the shifter and associated cabl...   Oct 6 2019, 03:11 PM
partwerks   Lyle - If you mean the shifter and associated cab...   Oct 6 2019, 03:33 PM
tygaboy   What is the numberic shifter? [/quote] This ...   Oct 6 2019, 06:33 PM
partwerks   Lyle - If you mean the shifter and associated cab...   Oct 6 2019, 05:36 PM
dakotaewing   Tony and Clay, The parts that I'm referring t...   Oct 6 2019, 04:45 PM
Cracker   Here you go Thom...allot less than $500! ...   Oct 6 2019, 05:23 PM
dakotaewing   Tony, I have the shift linkage indicated in the s...   Oct 6 2019, 06:01 PM
Cracker   I do not have those pieces on my box...it looks li...   Oct 6 2019, 06:41 PM
914forme   Generally the same, slight difference in CV flange...   Oct 6 2019, 06:03 PM
partwerks   Generally the same, slight difference in CV flang...   Oct 6 2019, 08:15 PM
FL 000   Generally the same, slight difference in CV flan...   Oct 8 2019, 07:45 PM
ClayPerrine   The G86-21 transmission has different cable attach...   Oct 6 2019, 06:30 PM
partwerks   I'm guessing that the adapter plate I have for...   Oct 7 2019, 08:46 PM
Cracker   Ok. I called Kennedy Engineering today for you...I...   Oct 8 2019, 05:44 PM
partwerks   Ok. I called Kennedy Engineering today for you......   Oct 8 2019, 07:23 PM
andys   Ok. I called Kennedy Engineering today for you.....   Oct 9 2019, 09:28 AM
partwerks   [quote name='partwerks' post='2753284' date='Oct ...   Oct 9 2019, 06:28 PM
dakotaewing   I must be getting old... $650 for a mass prod...   Oct 11 2019, 03:11 PM
partwerks   I must be getting old... $650 for a mass pro...   Oct 11 2019, 06:22 PM
Robarabian   Okay.. someone knew this was going to get asked......   Oct 8 2019, 07:31 PM
914forme   yes it has been done   Oct 8 2019, 07:43 PM
partwerks   yes it has been done These pictures are of a 6 ...   Oct 8 2019, 07:50 PM
Cracker   Good luck. Cracker   Oct 9 2019, 06:39 PM
Tdskip   Nothing to add except WOW guys, some neat engineer...   Oct 10 2019, 06:19 AM
partwerks   Would this clutch work, or is it heavy enough? ht...   Oct 11 2019, 09:20 PM
Mike Bellis   There are two (2) different 6 speed bellhousing bo...   Oct 13 2019, 10:24 PM
SirAndy   Embrace the suck... :D   Oct 14 2019, 02:37 PM
tygaboy   @Lof8 Here you go. A chunk of aluminum that was s...   Jul 2 2024, 03:16 PM
cooler   It's good to see this thread revived. I am usi...   Jul 2 2024, 05:13 PM
Wdrdb   It's good to see this thread revived. I am us...   Aug 8 2024, 11:06 PM
Lof8   @tygaboy that is nice solution that I hadn’t e...   Jul 3 2024, 04:43 AM
tygaboy   @[url=http://www.914world.com/bbs2/index.php?show...   Jul 3 2024, 06:52 AM
Lof8   @tygaboy Your spacers could be exactly what I nee...   Jul 3 2024, 07:02 AM
tygaboy   @[url=http://www.914world.com/bbs2/index.php?show...   Jul 3 2024, 03:50 PM
Lof8   I’ll reach out if 1.5” ends up being my magic ...   Jul 3 2024, 06:27 PM
Lof8   Hey 6-speeders, anyone have photos of how they pen...   Aug 1 2024, 07:52 AM
tygaboy   Hey 6-speeders, anyone have photos of how they pe...   Aug 1 2024, 08:14 AM
technicalninja   [b]@[url=http://www.914world.com/bbs2/index.php...   Aug 1 2024, 08:23 AM
ClayPerrine   I ran one of mine through the speedo cable hole, a...   Aug 1 2024, 01:46 PM
- Lo-Fi Version Time is now: 23rd November 2026 - 04:24 AM
