Would appreciate some tuning advice for new 2056, Having trouble dialing in the AFR |
rbzymek |
Oct 6 2019, 09:02 AM
Member Group: Members Posts: 195 Joined: 5-April 19 From: Northville, MI Member No.: 23,013 Region Association: Upper MidWest |
So I replaced the 1.8L with a SCAT 2056 long block with a Web 73 cam and 42x38 valves. They provided 4 bolt (intake) heads so I could use the 1.8 tin and carry over L-Jet system. The CR is 8.5 and I have an adjustable FPR. The injectors are stock 1.8L L-Ject. I can dial in the idle AFR easily but I get rich 9.0 AFR on very light tip in. I also go lean at higher speeds (>4000). I suspect the static is set too high on the AFM. Any suggestions?
914forme |
Oct 6 2019, 07:01 PM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
Best of luck and let us know where you land.
Lo-Fi Version | Time is now: 9th June 2024 - 09:59 PM |
