Would appreciate some tuning advice for new 2056, Having trouble dialing in the AFR |
rbzymek |
Oct 6 2019, 09:02 AM
Member Group: Members Posts: 195 Joined: 5-April 19 From: Northville, MI Member No.: 23,013 Region Association: Upper MidWest |
So I replaced the 1.8L with a SCAT 2056 long block with a Web 73 cam and 42x38 valves. They provided 4 bolt (intake) heads so I could use the 1.8 tin and carry over L-Jet system. The CR is 8.5 and I have an adjustable FPR. The injectors are stock 1.8L L-Ject. I can dial in the idle AFR easily but I get rich 9.0 AFR on very light tip in. I also go lean at higher speeds (>4000). I suspect the static is set too high on the AFM. Any suggestions?
djway |
Oct 7 2019, 09:34 PM
Senior Member Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
When trying to get the old tired 1.8 to run I just jumped on the freeway while watching the gauge under load then at cruise.
I would get off the freeway and adjust the spring pressure then hop back on the freeway. I kept doing it until the numbers looked acceptable. In my case it was dumping too much fuel so I tightened the spring. |
Lo-Fi Version | Time is now: 9th June 2024 - 10:00 PM |
