> Fluid on the floor: What could it be?, (time to take a brake?)Slight mystery upon returning from Okteenerfest
DRPHIL914
post Oct 6 2019, 09:11 AM
Dr. Phil
After returning from Okteenerfest the car sat a couple weeks, and after taking it to Cars and coffee I parked it again but backed in and a few days later pulled out and noticed 2 small puddles , front at rear- cleaned it up them parked the car , then a few days later checked again and it’s for sure under front.
I was initially worried that I had a front crank seal when I thought it was from the back, and I am releaved that it’s not from the motor,
I did all that last year and am proud to say it’s been a leak free motor since then, and I didn’t want to pull the motor or trans.
BUT this is brake fluid, and I can’t really explain why this would suddenly spring
A leak (IMG:style_emoticons/default/confused24.gif) . I replaced all brake lines and the 19mm master cylinder about 3-4 years ago, no leaks no issues since then.
And I don’t have loss of pressure on brakes so I am assuming it’s the supply line so I guess I will be pulling the belly pan to investigate. Will post more info when I get a look just wonder why just now? I know the washer is there under the supply line connection, just weird this started now???
Phil
DRPHIL914
post Oct 8 2019, 07:41 AM
Dr. Phil
So last night pulled carpet and took a look under he pedal board and no fluid under the
Pedals and m.c. inside, so next is tonight I will try and get car jacked up and pull the cover to steering and m.c. . Btw brake pedal is firm with no loss of pressure so I am expecting to see a leak at the supply line - More fluid on the floor after it’s just sitting for a few days so it’s just leaking out from gravity.
bdstone914
post Oct 8 2019, 08:02 AM
bdstone914
@DRPHIL914 ' post='2753114
[/quote]
You may need a mirror and flashlight to inspect the top of the master. My bet is a leak around the input lines.
A cheap cell phone endoscope is helpful to see into remote areas.
Bruce
DRPHIL914   Fluid on the floor: What could it be?   Oct 6 2019, 09:11 AM
bbrock   What MC did you install? There were a small numbe...   Oct 6 2019, 09:43 AM
DRPHIL914   What MC did you install? There were a small numb...   Oct 6 2019, 09:49 AM
76-914   Is there any fluid inside on the floorboard?   Oct 6 2019, 09:50 AM
DRPHIL914   Is there any fluid inside on the floorboard? Not...   Oct 6 2019, 09:53 AM
DRPHIL914   Is there any fluid inside on the floorboard? Aft...   Oct 8 2019, 07:06 PM
76-914   Just see if it is on the floorboard. If so, a cup ...   Oct 6 2019, 10:00 AM
rjames   Someone else can correct me if I’ve got this wro...   Oct 6 2019, 04:26 PM
DRPHIL914   So last night pulled carpet and took a look under ...   Oct 8 2019, 07:41 AM
bdstone914   @[url=http://www.914world.com/bbs2/index.php?showu...   Oct 8 2019, 08:02 AM
mepstein   Phillip - did you install the metal washers under ...   Oct 8 2019, 08:06 AM
DRPHIL914   Phillip - did you install the metal washers under...   Oct 8 2019, 09:09 AM
rjames   Phillip - did you install the metal washers unde...   Oct 8 2019, 10:50 AM
DRPHIL914   [quote name='DRPHIL914' post='2753129' date='Oct ...   Oct 8 2019, 07:24 PM
bdstone914   [quote name='DRPHIL914' post='2753129' date='Oct...   Oct 8 2019, 09:46 PM
DRPHIL914   Outside under MC and on top are dry, just wet at w...   Oct 8 2019, 07:22 PM
mepstein   I'm certainly no expert but it sounds like it ...   Oct 8 2019, 07:30 PM
DRPHIL914   Has anyone installed one of the MC from 914rubber?...   Oct 8 2019, 08:49 PM
mepstein   Has anyone installed one of the MC from 914rubber...   Oct 8 2019, 09:23 PM
Mikey914   I few have Ian made a video. Spend the extra coupl...   Oct 8 2019, 09:08 PM
Mikey914   No fluid on the bottom of the cylinder is indicati...   Oct 8 2019, 10:38 PM
DRPHIL914   No fluid on the bottom of the cylinder is indicat...   Oct 9 2019, 07:11 AM
DRPHIL914   No fluid on the bottom of the cylinder is indicat...   Oct 9 2019, 08:02 AM
Mikey914   No fluid on the bottom of the cylinder is indica...   Oct 10 2019, 03:27 PM
DRPHIL914   [quote name='DRPHIL914' post='2753392' date='Oct ...   Oct 16 2019, 06:21 AM
dr914@autoatlanta.com   yes master cylinder has failed. As much trouble as...   Oct 9 2019, 08:31 AM
DRPHIL914   yes master cylinder has failed. As much trouble a...   Oct 9 2019, 09:26 AM
DRPHIL914   I did get this project partly completed last night...   Oct 18 2019, 07:10 AM
Mikey914   Yes, mush easier job on a rack, If you need new li...   Oct 18 2019, 09:24 AM
Mikey914   Also, On the old one after yo get this done. Can y...   Oct 18 2019, 09:27 AM
DRPHIL914   Also, On the old one after yo get this done. Can ...   Oct 18 2019, 09:39 AM
DRPHIL914   I would assume this could be rebuilt and a new sea...   Oct 18 2019, 09:40 AM
76-914   I would assume this could be rebuilt and a new se...   Oct 18 2019, 10:19 AM
Mikey914   I would assume this could be rebuilt and a new se...   Oct 18 2019, 10:30 AM
malcolm2   Google.... Or I used duck duck go now, but search ...   Oct 18 2019, 10:46 AM
DRPHIL914   Google.... Or I used duck duck go now, but search...   Oct 18 2019, 01:16 PM
Mikey914   Interesting, We could on the next run do up extra ...   Oct 18 2019, 12:36 PM
malcolm2   Interesting, We could on the next run do up extra...   Oct 18 2019, 01:46 PM
IronHillRestorations   I have a 1500 mile master cylinder that needs a se...   Oct 18 2019, 01:41 PM
DRPHIL914   5 hours , MC in, pedals removed floor and pedal cl...   Oct 19 2019, 04:12 PM
DRPHIL914   Here is the MC that came out , leaking from front ...   Oct 19 2019, 06:14 PM
DRPHIL914   Another view I will probably order a rebuild kit ...   Oct 19 2019, 06:17 PM
Mikey914   Drop me a call tomorrow. You do want to put the ab...   Oct 19 2019, 11:13 PM
DRPHIL914   Drop me a call tomorrow. You do want to put the a...   Oct 19 2019, 11:42 PM
DRPHIL914   Spoke with Mark and we are pretty sure the wrong o...   Oct 22 2019, 07:06 AM
- Lo-Fi Version Time is now: 3rd November 2026 - 02:06 PM
