| billh1963 |
Oct 1 2019, 04:45 PM
Car Hoarder! ![]() ![]() ![]() ![]() Group: Members Posts: 3,444 Joined: 28-March 11 From: North Carolina Member No.: 12,871 Region Association: South East States |
Selling the car I picked up a few years ago. I've put a fair amount of work into this car and just had Bill Whitesides get some final issues resolved.
I'll start by listing the original ad (as it appeared on world...Original ad). This was the car as purchased by another forum member. I bought it from him with the 2.7 CIS installed. I'll list the specs of the car (modifying the description to show things that have changed) and then list the recent work: 1972 Irish Green. Originally Irish Green, painted yellow at some point in its life, then painted back to Irish Green. There is no rust on this car that I have seen and neither has Bill W (who dropped the engine and been all through the car inside and out..... he has seen everything there is to see). I don't believe the car has ever been hit. The front trunk pan has some minor damage by either running over something or an idiot with a jack. The paint is decent but has several small "bubbles" on the hood and several other flat surfaces from poor paint prep. I can't get them to show in a picture. Paint is pretty good and a good buffing would do wonders. Interior is very clean. The car has the very hard to find dark brown interior. Seats are good and dash is uncracked. Carpet is new. Everything works (except for heat...because, you know...headers) including the clock. Car runs and drives very well. 2.7L 911 CIS 6 cylinder engine with a 73 7R case Stainless steel brake lines Cross drilled and vented brakes 5 bolt Fuchs Alloys 6 x 16 with four year old Pirelli CINTURATO P7 205/55R16 and a Fuchs 6x16 spare Sway Bars front and rear Side shift transmission and shift mechanism 19 mm 911 Master cylinder M calipers front . Widened calipers rear with handbrake functional . New Brake pads front and rear New Bilstein front inserts ( shocks ) New Ball joints New rear shocks Boge and springs #140 lbs New Speedo Cable and Angle Drive New Carpets New Seat Belts ( and retractors ) New Fuel Pump ( relocated to front trunk ) Center Console with Gauges 911 oil pressure /oil temp gauge Porsche Oil tank New inner and outer rockers After I bought the car in 2015, I took it to Series 9 in DeLand Florida where Joe - resealed the engine - installed stainless steel fuel lines in the tunnel - installed a Bob Saville Naro engine mount - Installed MSD 6AC ignition I drove the car sparingly (too many other cars to drive). Plus, the transmission was well worn and I really didn't enjoy driving it that much. So, I had Dr. Evil build me a new transmission. That takes us to the present. I took the car to Bill W and he did the following: - Remove and replace transmission - Drop engine and replace alternator ($379 for alternator) - Replace shifter assembly - Weld broken clutch tube - Rebuild pedal cluster - Replace clutch cable - Change oil, replace warped oil sump plate - Four wheel laser alignment So, if you made it this far, you know the history of the car. Why am I selling? You may have seen my previous posts that Marathon Blue is my favorite color. I have everything needed to build a 6 conversion (including a '74 in Marathon blue). So, I'm going to build my own. Price is $22,000 obo. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
| billh1963 |
Oct 8 2019, 11:37 AM
Car is sold. Thank you for your interest!
| BK911 |
Oct 8 2019, 12:52 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
| billh1963 |
Oct 8 2019, 02:26 PM
Car is sold. Thank you for your interest! Thank goodness. It was a decent car when you got it, and you made it even better. Don't know how much longer I could have held off! It still needs some “elbow grease” and some cosmetic attention here and there. But, the car runs nice, electrically is in good shape (even the reverse lights work) and with the new Dr. Evil transmission shifts properly. The new owner can drive this car anywhere they want while deciding if they want to take it to the next level. |
billh1963 1972 914-6 conversion with 2.7 CIS and new transmission Oct 1 2019, 04:45 PM
Robdog1033 Do you have any pixs of the "Hellhole"? ... Oct 2 2019, 11:18 AM
billh1963 The picture of the hell hole is just below the pic... Oct 2 2019, 11:42 AM
IronHillRestorations Did that belong to Jason Panciera? Part of the wi... Oct 2 2019, 01:16 PM
billh1963
Did that belong to Jason Panciera? Part of the w... Oct 2 2019, 04:00 PM
nditiz1 Did they do a leak down on the motor? That will gi... Oct 2 2019, 02:18 PM
Robdog1033 Can you please give me a call when you have time t... Oct 3 2019, 02:51 PM
mepstein Bill is one of those guys that I would buy a car f... Oct 3 2019, 02:58 PM
billh1963
Bill is one of those guys that I would buy a car ... Oct 3 2019, 07:24 PM
burton73 More pictures of doon jams and trunks would really... Oct 3 2019, 03:17 PM
billh1963
More pictures of doon jams and trunks would reall... Oct 3 2019, 07:30 PM
Robdog1033 Hey Bill,
I'm new on these forums and obviousl... Oct 3 2019, 05:04 PM
billh1963
Hey Bill,
I'm new on these forums and obvious... Oct 3 2019, 07:35 PM
scottthephotog Sent a PM. Thanks! Oct 3 2019, 11:20 PM
billh1963 I appreciate the tremendous response I have had so... Oct 4 2019, 01:41 PM
914z Yup priced way too low but you are building a 74 ... Oct 5 2019, 04:00 PM
mtndawg I think people come out of the gate way too high a... Oct 5 2019, 04:58 PM
Tdskip
I think people come out of the gate way too high ... Oct 7 2019, 06:01 AM
914z
I think people come out of the gate way too high ... Oct 7 2019, 10:27 AM
billh1963
I think people come out of the gate way too high... Oct 7 2019, 10:41 AM
DRPHIL914
[quote name='914z' post='2752850' date='Oct 7 201... Oct 7 2019, 11:59 AM
ValcoOscar I'm a late player, wife said no more 914's... Oct 7 2019, 12:50 PM
I'm a late player, wife said no more 914... Oct 7 2019, 01:12 PM
billh1963
I'm a late player, wife said no more 914... Oct 7 2019, 01:55 PM
DRPHIL914
I'm a late player, wife said no more 914... Oct 7 2019, 03:36 PM
ndfrigi
[quote name='billh1963' post='2752907' date='Oct ... Oct 7 2019, 03:37 PM
Justinp71
I'm a late player, wife said no more 914... Oct 9 2019, 05:15 PM
914z
[quote name='BK911' post='2753172' date='Oct 8 20... Oct 9 2019, 11:03 AM
ndfrigi new owner a member here? is it Oscar? Oct 8 2019, 01:27 PM
billh1963 It’s a new member. I’ll leave it up to them if... Oct 8 2019, 01:54 PM
ndfrigi [quote name='billh1963' date='Oct 8 20... Oct 8 2019, 02:00 PM
EdwardBlume A very good buy. Congrats to the buyer and seller. Oct 9 2019, 07:13 AM
Robdog1033 Good morning Guys, I'm the lucky recipient of ... Oct 9 2019, 08:32 AM
ValcoOscar
Good morning Guys, I'm the lucky recipient of... Oct 9 2019, 08:49 AM
914z
Good morning Guys, I'm the lucky recipient of... Oct 9 2019, 11:01 AM
Good morning Guys, I'm the lucky recipient of... Oct 9 2019, 11:07 AM
ndfrigi Welcome to 914world @robdog1033 and congratulati... Oct 9 2019, 09:54 AM
nditiz1 Awesome Buy!
BTW why are you west coast guys ... Oct 9 2019, 02:28 PM
ValcoOscar
Awesome Buy!
BTW why are you west coast guys... Oct 9 2019, 02:53 PM
Awesome Buy!
BTW why are you west coast guy... Oct 9 2019, 03:21 PM
JOEPROPER
[quote name='nditiz1' post='2753481' date='Oct 9... Oct 9 2019, 03:45 PM
[quote name='ValcoOscar' post='2753490' date='Oc... Oct 9 2019, 04:57 PM
JOEPROPER :flag1: Oct 9 2019, 05:28 PM
flat4guy Congratulations. Is the car coming to Nor Cal or... Oct 9 2019, 08:35 PM
Robdog1033
Congratulations. Is the car coming to Nor Cal o... Oct 9 2019, 08:52 PM
914z
Congratulations. Is the car coming to Nor Cal ... Oct 10 2019, 10:59 AM
dax1969 Congratulations on the sale ....
Congratulations o... Oct 10 2019, 12:55 AM
Cairo94507 Congratulations to both parties and best wishes on... Oct 10 2019, 05:33 AM
flat4guy
Congratulations. Is the car coming to Nor Cal ... Oct 11 2019, 09:18 PM
Robdog1033 Great advise!! :agree: Oct 12 2019, 10:58 AM
Coondog Congrats, San Diego’s a big place. North or Sout... Oct 12 2019, 12:30 PM
Robdog1033 North S.D. County. I recieved the car late Sunday ... Oct 14 2019, 07:50 PM
billh1963 Enjoy in good health. Post some pictures in the re... Oct 15 2019, 01:20 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th November 2026 - 10:16 AM |
