> No power to injectors again!, Got spark, gas, at a total loss
surfdogskier
post Oct 7 2019, 06:22 PM
Oh my gosh!!!! She is back to doing this same thing all over again. I finally got her running . She ran fine one evening, parked her. Next day she would not start. No power to the injectors. I got spark. I got gas in the lines. Fuel pump works like it should. I took the distributor out and cleaned the trigger points to see if that would help. All wires are connected. MPS connected. All vacuum lines connected. I bought a noid light set up and they are definitely not getting power.
What else could it be? Something on the relay board? Bad relay?
This car is driving me insane. I am about to go duel carbs and drop this piece of **** fuel injection if I can't get this thing running.
surfdogskier
post Oct 7 2019, 07:47 PM
I will do that tomorrow and post back.....Thanks for the help.
914_teener
post Oct 8 2019, 02:50 PM
QUOTE(surfdogskier @ Oct 7 2019, 06:47 PM) *
Ring out the wires on the harness as Jeff suggests.
Once you get the harness eliminated I'd seriously consider an electronic distributor like the 123 and never worry about it again. You can always upgrade your motor if you decide to go bigger later and just change the dip switch setting.
surfdogskier   No power to injectors again!   Oct 7 2019, 06:22 PM
Mikey914   It injection is the best way to go if you can keep...   Oct 7 2019, 06:27 PM
surfdogskier   It injection is the best way to go if you can kee...   Oct 7 2019, 06:52 PM
JeffBowlsby   I know you said “all wires” but does that incl...   Oct 7 2019, 06:51 PM
JeffBowlsby   Dup post, sorry   Oct 7 2019, 06:52 PM
surfdogskier   I know you said “all wires” but does that inc...   Oct 7 2019, 06:54 PM
JeffBowlsby   Remove the ECU from the FI harness. Leave the har...   Oct 7 2019, 07:10 PM
Mikey914   Check power on 16 and 24 if not possible relay boa...   Oct 7 2019, 07:25 PM
surfdogskier   I will do that tomorrow and post back.....Thanks f...   Oct 7 2019, 07:47 PM
914_teener   I will do that tomorrow and post back.....Thanks ...   Oct 8 2019, 02:50 PM
surfdogskier   In order to check the 16 and 24 pin, do I have to ...   Oct 8 2019, 02:50 PM
JeffBowlsby   Yes to the first question. No to the second. Sli...   Oct 8 2019, 03:51 PM
surfdogskier   Yes to the first question. No to the second. Sl...   Oct 8 2019, 05:41 PM
jim_hoyland   Congratulations Lawrence. I loved your 914. Gre...   Oct 8 2019, 04:18 PM
surfdogskier   I do have 12v at 24 and 16.   Oct 8 2019, 06:21 PM
IronHillRestorations   Just because you cleaned the trigger points, does ...   Oct 8 2019, 06:25 PM
IronHillRestorations   Just because you cleaned the trigger points, does ...   Oct 8 2019, 06:32 PM
surfdogskier   Just because you cleaned the trigger points, does...   Oct 8 2019, 07:26 PM
JeffBowlsby   Then you have power to the ECU. Somewhere between...   Oct 8 2019, 07:12 PM
surfdogskier   Then you have power to the ECU. Somewhere betwee...   Oct 8 2019, 07:29 PM
surfdogskier   Then you have power to the ECU. Somewhere betwee...   Oct 9 2019, 07:09 PM
surfdogskier   I do want to mention. If she sets for a little wh...   Oct 8 2019, 07:36 PM
914_teener   I do want to mention. If she sets for a little w...   Oct 9 2019, 09:58 AM
dr914@autoatlanta.com   probably two of the injectors spitting a bit of ga...   Oct 9 2019, 03:03 PM
surfdogskier   I is like it has a drop of gas to tease it. I tri...   Oct 9 2019, 06:23 PM
Bartlett 914   How do you know you are not getting power the the ...   Oct 9 2019, 02:59 PM
surfdogskier   How do you know you are not getting power the the...   Oct 9 2019, 06:24 PM
Bartlett 914   How do you know you are not getting power the th...   Oct 12 2019, 03:25 PM
surfdogskier   [quote name='surfdogskier' post='2753548' date='O...   Oct 12 2019, 06:04 PM
ClayPerrine   Anyone interested in a fuel injection set up, I w...   Oct 12 2019, 06:54 PM
surfdogskier   Anyone interested in a fuel injection set up, I ...   Oct 12 2019, 09:41 PM
surfdogskier   I decided I am finished with fuel injection. I do...   Oct 11 2019, 09:38 AM
ClayPerrine   I decided I am finished with fuel injection. I d...   Oct 11 2019, 09:41 AM
surfdogskier   I decided I am finished with fuel injection. I ...   Oct 11 2019, 07:30 PM
IronHillRestorations   Just don't over size the carbs; bigger isn...   Oct 12 2019, 07:27 AM
rhodyguy   By the time you've done the swap you'll be...   Oct 12 2019, 07:16 PM
surfdogskier   By the time you've done the swap you'll b...   Oct 12 2019, 09:40 PM
JeffBowlsby   Surfdog, please don't take this personally, ju...   Oct 13 2019, 12:10 AM
surfdogskier   Surfdog, please don't take this personally, j...   Oct 13 2019, 08:32 AM
JeffBowlsby   No worries Surfdog, you are entitled to make the d...   Oct 13 2019, 10:13 AM
- Lo-Fi Version Time is now: 10th September 2026 - 07:00 PM
