| surfdogskier |
Oct 7 2019, 06:22 PM
Member ![]() ![]() Group: Members Posts: 164 Joined: 20-May 16 From: East TN Member No.: 20,019 Region Association: None |
Oh my gosh!!!! She is back to doing this same thing all over again. I finally got her running . She ran fine one evening, parked her. Next day she would not start. No power to the injectors. I got spark. I got gas in the lines. Fuel pump works like it should. I took the distributor out and cleaned the trigger points to see if that would help. All wires are connected. MPS connected. All vacuum lines connected. I bought a noid light set up and they are definitely not getting power.
What else could it be? Something on the relay board? Bad relay? This car is driving me insane. I am about to go duel carbs and drop this piece of **** fuel injection if I can't get this thing running. |
| jim_hoyland |
Oct 8 2019, 04:18 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,129 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
Congratulations Lawrence. I loved your 914. Great looking car with just the right attitude. I am sure you will love the 911 and I wish you nothing but the best with it. The 3.0 is a terrific motor and with the limited slip 915 you should have lots of fun. I have flip-flopped back and forth between 911's and 914-6's for the last 40 years. In the end the 914-6 was the winner for me. I may buy an '89 Carrera coupe one of these days if I am around long enough. That is the only 911 I really want to share the garage with the 914-6. Cheers and I hope to see you soon. Michael (IMG:style_emoticons/default/beerchug.gif) What's going on at 16 and 24 ? Power coming inputs ? Or ? |
surfdogskier No power to injectors again! Oct 7 2019, 06:22 PM
Mikey914 It injection is the best way to go if you can keep... Oct 7 2019, 06:27 PM
surfdogskier
It injection is the best way to go if you can kee... Oct 7 2019, 06:52 PM
JeffBowlsby I know you said “all wires” but does that incl... Oct 7 2019, 06:51 PM
JeffBowlsby Dup post, sorry Oct 7 2019, 06:52 PM
surfdogskier
I know you said “all wires” but does that inc... Oct 7 2019, 06:54 PM
JeffBowlsby Remove the ECU from the FI harness. Leave the har... Oct 7 2019, 07:10 PM
Mikey914 Check power on 16 and 24 if not possible relay boa... Oct 7 2019, 07:25 PM
surfdogskier I will do that tomorrow and post back.....Thanks f... Oct 7 2019, 07:47 PM
914_teener
I will do that tomorrow and post back.....Thanks ... Oct 8 2019, 02:50 PM
surfdogskier In order to check the 16 and 24 pin, do I have to ... Oct 8 2019, 02:50 PM
JeffBowlsby Yes to the first question. No to the second.
Sli... Oct 8 2019, 03:51 PM
surfdogskier
Sl... Oct 8 2019, 05:41 PM
surfdogskier I do have 12v at 24 and 16. Oct 8 2019, 06:21 PM
IronHillRestorations Just because you cleaned the trigger points, does ... Oct 8 2019, 06:25 PM
IronHillRestorations Just because you cleaned the trigger points, does ... Oct 8 2019, 06:32 PM
surfdogskier
Just because you cleaned the trigger points, does... Oct 8 2019, 07:26 PM
JeffBowlsby Then you have power to the ECU. Somewhere between... Oct 8 2019, 07:12 PM
surfdogskier
Then you have power to the ECU. Somewhere betwee... Oct 8 2019, 07:29 PM
surfdogskier
Then you have power to the ECU. Somewhere betwee... Oct 9 2019, 07:09 PM
surfdogskier I do want to mention. If she sets for a little wh... Oct 8 2019, 07:36 PM
914_teener
I do want to mention. If she sets for a little w... Oct 9 2019, 09:58 AM
dr914@autoatlanta.com probably two of the injectors spitting a bit of ga... Oct 9 2019, 03:03 PM
surfdogskier I is like it has a drop of gas to tease it. I tri... Oct 9 2019, 06:23 PM
Bartlett 914 How do you know you are not getting power the the ... Oct 9 2019, 02:59 PM
surfdogskier
How do you know you are not getting power the the... Oct 9 2019, 06:24 PM
Bartlett 914
How do you know you are not getting power the th... Oct 12 2019, 03:25 PM
surfdogskier
[quote name='surfdogskier' post='2753548' date='O... Oct 12 2019, 06:04 PM
ClayPerrine
Anyone interested in a fuel injection set up, I w... Oct 12 2019, 06:54 PM
surfdogskier
Anyone interested in a fuel injection set up, I ... Oct 12 2019, 09:41 PM
surfdogskier I decided I am finished with fuel injection. I do... Oct 11 2019, 09:38 AM
ClayPerrine
I decided I am finished with fuel injection. I d... Oct 11 2019, 09:41 AM
surfdogskier
I decided I am finished with fuel injection. I ... Oct 11 2019, 07:30 PM
IronHillRestorations Just don't over size the carbs; bigger isn... Oct 12 2019, 07:27 AM
rhodyguy By the time you've done the swap you'll be... Oct 12 2019, 07:16 PM
surfdogskier
By the time you've done the swap you'll b... Oct 12 2019, 09:40 PM
JeffBowlsby Surfdog, please don't take this personally, ju... Oct 13 2019, 12:10 AM
surfdogskier
Surfdog, please don't take this personally, j... Oct 13 2019, 08:32 AM
JeffBowlsby No worries Surfdog, you are entitled to make the d... Oct 13 2019, 10:13 AM![]() ![]() |
Lo-Fi Version | Time is now: 10th September 2026 - 07:00 PM |
