| partwerks |
Oct 5 2019, 02:50 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,642 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
The Boxster "S" 6 speed trans, that is used with the LS3 engine. Are all of the transaxles geared differently, or all the same?
Is anyone else running the Boxster "S" 6 speed, with an LS engine? |
| Cracker |
Oct 8 2019, 05:44 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States
Ok. I called Kennedy Engineering today for you...I do not have good news. According to them, the base Boxster 5-speed adapter plate will not work with the Boxster S 6-speed. It does not matter whether or not you drilled the mounting holes.
The "kit" they sell includes everything needed to mate the 6-speed an LS engine. It costs about $2,800 + shipping. Good luck! Tony |
| partwerks |
Oct 8 2019, 07:23 PM
Ok. I called Kennedy Engineering today for you...I do not have good news. According to them, the base Boxster 5-speed adapter plate will not work with the Boxster S 6-speed. It does not matter whether or not you drilled the mounting holes. The "kit" they sell includes everything needed to mate the 6-speed an LS engine. It costs about $2,800 + shipping. Good luck! Tony Thanks Tony! I am still waiting for a reply back from kitcarchassis.com, if the starter I now have, will work on the 6 speed, and my current adapter plate. So far this is what I have heard back: Yes, the 5 and 6 speed use the same holes. The early 6 speed uses a couple of less holes than the 5 speed and later 6 speed but they are located in the same places. You just need the correct clutch for which ever transmission you are using. I will have to check part numbers but I think you will need a full clutch kit. |
partwerks Boxster "S" 6 speed trans Oct 5 2019, 02:50 PM
tygaboy The Boxster S trans is the G86-20. All of those ha... Oct 5 2019, 03:38 PM
partwerks
The Boxster S trans is the G86-20. All of those h... Oct 13 2019, 03:16 PM
Cracker Lyle,
I replied to your PM...the system is amazin... Oct 5 2019, 07:21 PM
partwerks
Lyle,
I replied to your PM...the system is amazi... Oct 5 2019, 08:48 PM
ClayPerrine I have a 2006 Cayman S G86-21 trans in my car. It... Oct 5 2019, 09:10 PM
partwerks Any pictures of what trans mount Renegade Hybrids ... Oct 5 2019, 09:50 PM
Joemo5
Any pictures of what trans mount Renegade Hybrids... Oct 5 2019, 10:33 PM
Cracker 1) If there IS one downside of the Renegade mount ... Oct 6 2019, 06:56 AM
tygaboy I'd bet that Tony has the market cornered on s... Oct 6 2019, 09:12 AM
Lof8
But so far, so good on the Renegade design. I... Jul 2 2024, 01:01 PM
dakotaewing Tony and Clay,
What did each of you do to address... Oct 6 2019, 11:00 AM
Cracker I have not seen a used box posted for sale that di... Oct 6 2019, 11:24 AM
tygaboy Lyle - If you mean the shifter and associated cabl... Oct 6 2019, 03:11 PM
partwerks
Lyle - If you mean the shifter and associated cab... Oct 6 2019, 03:33 PM
tygaboy
What is the numberic shifter?
[/quote]
This ... Oct 6 2019, 06:33 PM
partwerks
Lyle - If you mean the shifter and associated cab... Oct 6 2019, 05:36 PM
The parts that I'm referring t... Oct 6 2019, 04:45 PM
Cracker Here you go Thom...allot less than $500! ... Oct 6 2019, 05:23 PM
dakotaewing Tony,
I have the shift linkage indicated in the s... Oct 6 2019, 06:01 PM
Cracker I do not have those pieces on my box...it looks li... Oct 6 2019, 06:41 PM
914forme Generally the same, slight difference in CV flange... Oct 6 2019, 06:03 PM
partwerks
Generally the same, slight difference in CV flang... Oct 6 2019, 08:15 PM
FL 000
Generally the same, slight difference in CV flan... Oct 8 2019, 07:45 PM
ClayPerrine The G86-21 transmission has different cable attach... Oct 6 2019, 06:30 PM
partwerks I'm guessing that the adapter plate I have for... Oct 7 2019, 08:46 PM
andys
Ok. I called Kennedy Engineering today for you..... Oct 9 2019, 09:28 AM
partwerks
[quote name='partwerks' post='2753284' date='Oct ... Oct 9 2019, 06:28 PM
dakotaewing I must be getting old... $650 for a mass prod... Oct 11 2019, 03:11 PM
partwerks
I must be getting old... $650 for a mass pro... Oct 11 2019, 06:22 PM
Robarabian Okay.. someone knew this was going to get asked...... Oct 8 2019, 07:31 PM
914forme yes it has been done Oct 8 2019, 07:43 PM
partwerks
These pictures are of a 6 ... Oct 8 2019, 07:50 PM
Cracker Good luck.
Cracker Oct 9 2019, 06:39 PM
Tdskip Nothing to add except WOW guys, some neat engineer... Oct 10 2019, 06:19 AM
partwerks Would this clutch work, or is it heavy enough?
ht... Oct 11 2019, 09:20 PM
Mike Bellis There are two (2) different 6 speed bellhousing bo... Oct 13 2019, 10:24 PM
SirAndy Embrace the suck...
:D Oct 14 2019, 02:37 PM
tygaboy @Lof8 Here you go. A chunk of aluminum that was s... Jul 2 2024, 03:16 PM
cooler It's good to see this thread revived. I am usi... Jul 2 2024, 05:13 PM
Wdrdb
It's good to see this thread revived. I am us... Aug 8 2024, 11:06 PM
Lof8 @tygaboy that is nice solution that I hadn’t e... Jul 3 2024, 04:43 AM
tygaboy
@[url=http://www.914world.com/bbs2/index.php?show... Jul 3 2024, 06:52 AM
Lof8 @tygaboy Your spacers could be exactly what I nee... Jul 3 2024, 07:02 AM
tygaboy
@[url=http://www.914world.com/bbs2/index.php?show... Jul 3 2024, 03:50 PM
Lof8 I’ll reach out if 1.5” ends up being my magic ... Jul 3 2024, 06:27 PM
Lof8 Hey 6-speeders, anyone have photos of how they pen... Aug 1 2024, 07:52 AM
tygaboy
Hey 6-speeders, anyone have photos of how they pe... Aug 1 2024, 08:14 AM
technicalninja
[b]@[url=http://www.914world.com/bbs2/index.php... Aug 1 2024, 08:23 AM
ClayPerrine I ran one of mine through the speedo cable hole, a... Aug 1 2024, 01:46 PM![]() ![]() |
Lo-Fi Version | Time is now: 23rd November 2026 - 04:24 AM |
