| surfdogskier |
Oct 7 2019, 06:22 PM
Member ![]() ![]() Group: Members Posts: 164 Joined: 20-May 16 From: East TN Member No.: 20,019 Region Association: None |
Oh my gosh!!!! She is back to doing this same thing all over again. I finally got her running . She ran fine one evening, parked her. Next day she would not start. No power to the injectors. I got spark. I got gas in the lines. Fuel pump works like it should. I took the distributor out and cleaned the trigger points to see if that would help. All wires are connected. MPS connected. All vacuum lines connected. I bought a noid light set up and they are definitely not getting power.
What else could it be? Something on the relay board? Bad relay? This car is driving me insane. I am about to go duel carbs and drop this piece of **** fuel injection if I can't get this thing running. |
| JeffBowlsby |
Oct 8 2019, 07:12 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,349 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
Then you have power to the ECU. Somewhere between the harness plug and the 2 wire injector connectors is the discontinuity. The trigger points initiate the voltage pulse to the injectors. The ECU processes the several engine sensors to determine the pulse width. No power to the injectors at idle could be worn out trigger points, a bad ECU, disconnected injector grounds, bad harness wiring. Maybe more. I would check the trigger points as has been mentioned, use an ohmmeter. Pull the dizzy, or check it in the car while cranking. You are looking for alternating continuity between the center pole and each of the two outer poles as the diz is rotated. No continuity, no pulse, no voltage, noid light no worky.
| surfdogskier |
Oct 8 2019, 07:29 PM
Then you have power to the ECU. Somewhere between the harness plug and the 2 wire injector connectors is the discontinuity. The trigger points initiate the voltage pulse to the injectors. The ECU processes the several engine sensors to determine the pulse width. No power to the injectors at idle could be worn out trigger points, a bad ECU, disconnected injector grounds, bad harness wiring. Maybe more. I would check the trigger points as has been mentioned, use an ohmmeter. Pull the dizzy, or check it in the car while cranking. You are looking for alternating continuity between the center pole and each of the two outer poles as the diz is rotated. No continuity, no pulse, no voltage, noid light no worky. Not a big deal to take her out. I will pull it tomorrow and try this....Thanks again for all the help Jeff. Much appreciated. |
surfdogskier No power to injectors again! Oct 7 2019, 06:22 PM
Mikey914 It injection is the best way to go if you can keep... Oct 7 2019, 06:27 PM
surfdogskier
It injection is the best way to go if you can kee... Oct 7 2019, 06:52 PM
JeffBowlsby I know you said “all wires” but does that incl... Oct 7 2019, 06:51 PM
JeffBowlsby Dup post, sorry Oct 7 2019, 06:52 PM
surfdogskier
I know you said “all wires” but does that inc... Oct 7 2019, 06:54 PM
JeffBowlsby Remove the ECU from the FI harness. Leave the har... Oct 7 2019, 07:10 PM
Mikey914 Check power on 16 and 24 if not possible relay boa... Oct 7 2019, 07:25 PM
surfdogskier I will do that tomorrow and post back.....Thanks f... Oct 7 2019, 07:47 PM
914_teener
I will do that tomorrow and post back.....Thanks ... Oct 8 2019, 02:50 PM
surfdogskier In order to check the 16 and 24 pin, do I have to ... Oct 8 2019, 02:50 PM
JeffBowlsby Yes to the first question. No to the second.
Sli... Oct 8 2019, 03:51 PM
surfdogskier
Sl... Oct 8 2019, 05:41 PM
jim_hoyland
Congratulations Lawrence. I loved your 914. Gre... Oct 8 2019, 04:18 PM
surfdogskier I do have 12v at 24 and 16. Oct 8 2019, 06:21 PM
IronHillRestorations Just because you cleaned the trigger points, does ... Oct 8 2019, 06:25 PM
IronHillRestorations Just because you cleaned the trigger points, does ... Oct 8 2019, 06:32 PM
surfdogskier
Just because you cleaned the trigger points, does... Oct 8 2019, 07:26 PM
surfdogskier
Then you have power to the ECU. Somewhere betwee... Oct 9 2019, 07:09 PM
surfdogskier I do want to mention. If she sets for a little wh... Oct 8 2019, 07:36 PM
914_teener
I do want to mention. If she sets for a little w... Oct 9 2019, 09:58 AM
dr914@autoatlanta.com probably two of the injectors spitting a bit of ga... Oct 9 2019, 03:03 PM
surfdogskier I is like it has a drop of gas to tease it. I tri... Oct 9 2019, 06:23 PM
Bartlett 914 How do you know you are not getting power the the ... Oct 9 2019, 02:59 PM
surfdogskier
How do you know you are not getting power the the... Oct 9 2019, 06:24 PM
Bartlett 914
How do you know you are not getting power the th... Oct 12 2019, 03:25 PM
surfdogskier
[quote name='surfdogskier' post='2753548' date='O... Oct 12 2019, 06:04 PM
ClayPerrine
Anyone interested in a fuel injection set up, I w... Oct 12 2019, 06:54 PM
surfdogskier
Anyone interested in a fuel injection set up, I ... Oct 12 2019, 09:41 PM
surfdogskier I decided I am finished with fuel injection. I do... Oct 11 2019, 09:38 AM
ClayPerrine
I decided I am finished with fuel injection. I d... Oct 11 2019, 09:41 AM
surfdogskier
I decided I am finished with fuel injection. I ... Oct 11 2019, 07:30 PM
IronHillRestorations Just don't over size the carbs; bigger isn... Oct 12 2019, 07:27 AM
rhodyguy By the time you've done the swap you'll be... Oct 12 2019, 07:16 PM
surfdogskier
By the time you've done the swap you'll b... Oct 12 2019, 09:40 PM
JeffBowlsby Surfdog, please don't take this personally, ju... Oct 13 2019, 12:10 AM
surfdogskier
Surfdog, please don't take this personally, j... Oct 13 2019, 08:32 AM
JeffBowlsby No worries Surfdog, you are entitled to make the d... Oct 13 2019, 10:13 AM![]() ![]() |
Lo-Fi Version | Time is now: 10th September 2026 - 07:00 PM |
