| DRPHIL914 |
Oct 6 2019, 09:11 AM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,971 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
After returning from Okteenerfest the car sat a couple weeks, and after taking it to Cars and coffee I parked it again but backed in and a few days later pulled out and noticed 2 small puddles , front at rear- cleaned it up them parked the car , then a few days later checked again and it’s for sure under front.
I was initially worried that I had a front crank seal when I thought it was from the back, and I am releaved that it’s not from the motor, I did all that last year and am proud to say it’s been a leak free motor since then, and I didn’t want to pull the motor or trans. BUT this is brake fluid, and I can’t really explain why this would suddenly spring A leak (IMG:style_emoticons/default/confused24.gif) . I replaced all brake lines and the 19mm master cylinder about 3-4 years ago, no leaks no issues since then. And I don’t have loss of pressure on brakes so I am assuming it’s the supply line so I guess I will be pulling the belly pan to investigate. Will post more info when I get a look just wonder why just now? I know the washer is there under the supply line connection, just weird this started now??? Phil |
| dr914@autoatlanta.com |
Oct 9 2019, 08:31 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,251 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
yes master cylinder has failed. As much trouble as they are to replace I would purchase a new fte or ate cylinder and install after cleaning up the pedal cluster area of brake fluid and resultant debris and bleed thoroughly with ate brake fluid. The 19mm master cylinder is not that expensive can be bought for 220 at any of the usual suppliers, and is well worth it. 914 17mm has been discontinued
DRPHIL914 Fluid on the floor: What could it be? Oct 6 2019, 09:11 AM
bbrock What MC did you install? There were a small numbe... Oct 6 2019, 09:43 AM
DRPHIL914
What MC did you install? There were a small numb... Oct 6 2019, 09:49 AM
76-914 Is there any fluid inside on the floorboard? Oct 6 2019, 09:50 AM
DRPHIL914
Not... Oct 6 2019, 09:53 AM
DRPHIL914
Aft... Oct 8 2019, 07:06 PM
76-914 Just see if it is on the floorboard. If so, a cup ... Oct 6 2019, 10:00 AM
rjames Someone else can correct me if I’ve got this wro... Oct 6 2019, 04:26 PM
DRPHIL914 So last night pulled carpet and took a look under ... Oct 8 2019, 07:41 AM
bdstone914 @[url=http://www.914world.com/bbs2/index.php?showu... Oct 8 2019, 08:02 AM
mepstein Phillip - did you install the metal washers under ... Oct 8 2019, 08:06 AM
DRPHIL914
Phillip - did you install the metal washers under... Oct 8 2019, 09:09 AM
rjames
Phillip - did you install the metal washers unde... Oct 8 2019, 10:50 AM
DRPHIL914
[quote name='DRPHIL914' post='2753129' date='Oct ... Oct 8 2019, 07:24 PM
bdstone914
[quote name='DRPHIL914' post='2753129' date='Oct... Oct 8 2019, 09:46 PM
DRPHIL914 Outside under MC and on top are dry, just wet at w... Oct 8 2019, 07:22 PM
mepstein I'm certainly no expert but it sounds like it ... Oct 8 2019, 07:30 PM
DRPHIL914 Has anyone installed one of the MC from 914rubber?... Oct 8 2019, 08:49 PM
Has anyone installed one of the MC from 914rubber... Oct 8 2019, 09:23 PM
Mikey914 I few have Ian made a video. Spend the extra coupl... Oct 8 2019, 09:08 PM
Mikey914 No fluid on the bottom of the cylinder is indicati... Oct 8 2019, 10:38 PM
DRPHIL914
No fluid on the bottom of the cylinder is indicat... Oct 9 2019, 07:11 AM
DRPHIL914
No fluid on the bottom of the cylinder is indicat... Oct 9 2019, 08:02 AM
Mikey914
No fluid on the bottom of the cylinder is indica... Oct 10 2019, 03:27 PM
DRPHIL914
[quote name='DRPHIL914' post='2753392' date='Oct ... Oct 16 2019, 06:21 AM
DRPHIL914
yes master cylinder has failed. As much trouble a... Oct 9 2019, 09:26 AM
DRPHIL914 I did get this project partly completed last night... Oct 18 2019, 07:10 AM
Mikey914 Yes, mush easier job on a rack, If you need new li... Oct 18 2019, 09:24 AM
Mikey914 Also,
On the old one after yo get this done. Can y... Oct 18 2019, 09:27 AM
DRPHIL914
Also,
On the old one after yo get this done. Can ... Oct 18 2019, 09:39 AM
DRPHIL914 I would assume this could be rebuilt and a new sea... Oct 18 2019, 09:40 AM
76-914
I would assume this could be rebuilt and a new se... Oct 18 2019, 10:19 AM
Mikey914
I would assume this could be rebuilt and a new se... Oct 18 2019, 10:30 AM
malcolm2 Google.... Or I used duck duck go now, but search ... Oct 18 2019, 10:46 AM
DRPHIL914
Google.... Or I used duck duck go now, but search... Oct 18 2019, 01:16 PM
Mikey914 Interesting,
We could on the next run do up extra ... Oct 18 2019, 12:36 PM
malcolm2
Interesting,
We could on the next run do up extra... Oct 18 2019, 01:46 PM
IronHillRestorations I have a 1500 mile master cylinder that needs a se... Oct 18 2019, 01:41 PM
DRPHIL914 5 hours , MC in, pedals removed floor and pedal cl... Oct 19 2019, 04:12 PM
DRPHIL914 Here is the MC that came out , leaking from front ... Oct 19 2019, 06:14 PM
DRPHIL914 Another view
I will probably order a rebuild kit ... Oct 19 2019, 06:17 PM
Mikey914 Drop me a call tomorrow. You do want to put the ab... Oct 19 2019, 11:13 PM
DRPHIL914
Drop me a call tomorrow. You do want to put the a... Oct 19 2019, 11:42 PM
DRPHIL914 Spoke with Mark and we are pretty sure the wrong o... Oct 22 2019, 07:06 AM![]() ![]() |
Lo-Fi Version | Time is now: 3rd November 2026 - 02:05 PM |
