| andreic |
Oct 9 2019, 08:15 AM
Member ![]() ![]() Group: Members Posts: 172 Joined: 21-December 15 From: Madison, WI Member No.: 19,479 Region Association: Upper MidWest |
Hello,
another question on my 1972 914. Since it just got colder, I reinstalled the heat boxes and the hoses providing heat in the car. The problem is that now there is a nasty smell in the cabin as I drive, **even** with the heater lever closed. Could it be that old grease on the heater boxes gets heated up and smells? Would this be fixed by putting the heater boxes in a parts cleaner and giving them a good cleaning? Thanks. |
| Tdskip |
Oct 10 2019, 06:22 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,784 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
For new (or newish) owners here how best to access the longs to get a vacuum in there and do you need any special attachment to access everything?
| mepstein |
Oct 10 2019, 07:00 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,013 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
For new (or newish) owners here how best to access the longs to get a vacuum in there and do you need any special attachment to access everything? Remove hose clamp from 4” pink heat tubing and shove a vacuum hose or plastic tube in the long. It’s a straight shot. I just use our home vacuum. I’ve found mouse nests, dog food, nuts and acorns. I agree with Kevin. You should be able to spray soap or solvent in each of the openings of the heat exchanger and then run a hose down and flush it out. If water comes out the exhaust, well then you know you have bigger problems. |
andreic Smelly heat Oct 9 2019, 08:15 AM
dr914@autoatlanta.com mice have died inside the longs, typical problem
... Oct 9 2019, 08:22 AM
mangrum Mine was in the fresh air box. Not so fresh air... Oct 9 2019, 10:15 AM
mepstein Even though it’s probably the heat exchangers, I... Oct 9 2019, 08:33 AM
rjames Whatever your smelling it's likely toxic. You ... Oct 9 2019, 10:11 AM
andreic First off, I removed the heater boxes and the hose... Oct 9 2019, 12:11 PM
mepstein To test, you plug up one end and pressure test or ... Oct 9 2019, 12:21 PM
rhodyguy If you wipe your finger where the hot air exits, i... Oct 9 2019, 05:48 PM
tvdinnerbythepool Not sure if it applies but I had burning oil smell... Oct 10 2019, 03:22 PM
second wind So just how do the mice get into the longs? How c... Oct 10 2019, 09:51 PM
Tdskip
So just how do the mice get into the longs? How ... Oct 11 2019, 07:05 AM
So just how do the mice get into the longs? How... Oct 11 2019, 07:18 AM
rhodyguy Electronic mouse trap. They really work. No poison... Oct 11 2019, 07:28 AM
dr914@autoatlanta.com We once purchased a pristine nepal orange 75 2.0 f... Oct 11 2019, 08:10 AM
StarBear Ah -- rust or fire; maybe about 90% of causes of 9... Oct 11 2019, 08:34 AM![]() ![]() |
Lo-Fi Version | Time is now: 23rd November 2026 - 06:51 AM |
