Would appreciate some tuning advice for new 2056, Having trouble dialing in the AFR |
rbzymek |
Oct 6 2019, 09:02 AM
Member Group: Members Posts: 195 Joined: 5-April 19 From: Northville, MI Member No.: 23,013 Region Association: Upper MidWest |
So I replaced the 1.8L with a SCAT 2056 long block with a Web 73 cam and 42x38 valves. They provided 4 bolt (intake) heads so I could use the 1.8 tin and carry over L-Jet system. The CR is 8.5 and I have an adjustable FPR. The injectors are stock 1.8L L-Ject. I can dial in the idle AFR easily but I get rich 9.0 AFR on very light tip in. I also go lean at higher speeds (>4000). I suspect the static is set too high on the AFM. Any suggestions?
djway |
Oct 10 2019, 06:29 PM
Senior Member Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
Close down your AFM bypass screw, it should Richen it up at idle then tighten your spring slightly to get your wide open throttle at the right point assuming your fifth injector is working properly.
rbzymek |
Oct 10 2019, 07:12 PM
Close down your AFM bypass screw, it should Richen it up at idle then tighten your spring slightly to get your wide open throttle at the right point assuming your fifth injector is working properly. I will try again next week. I need to demo a kitchen at the cottage this weekend. |
Lo-Fi Version | Time is now: 2nd June 2024 - 01:08 AM |
