| surfdogskier |
Oct 14 2019, 06:03 PM
Member ![]() ![]() Group: Members Posts: 164 Joined: 20-May 16 From: East TN Member No.: 20,019 Region Association: None |
So before I go ballistic and switch over to dual carbs, I just want to check one more thing. The only thing I can see that I see could be the reason my injectors are not firing is due to the MPS.
Is there a way I can check to see if the MPS is working properly using an ohm meter or other device? I see the wire on the MPS has the numbers 7,8, 10, 15. I would like to check the continuity of these wires as well. Where is the other end locate? Thanks |
| dr914@autoatlanta.com |
Oct 15 2019, 10:37 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,232 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
do not give up! If you send us your control unit and manifold pressure sensor we will check for free, do it all of the time for customers
surfdogskier How to test MPS Oct 14 2019, 06:03 PM
BeatNavy A bad MPS shouldn't cause injectors not to fir... Oct 14 2019, 06:16 PM
JamesM
A bad MPS shouldn't cause injectors not to fi... Oct 15 2019, 10:28 AM
Highland
1. Continuity tests of primary and secondary coi... Nov 10 2020, 09:56 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:07 PM |
