Steel wheels hub centric? |
Stltri |
Aug 10 2018, 10:58 AM
Member Group: Members Posts: 70 Joined: 13-April 15 From: SoCal Member No.: 18,622 Region Association: None |
Are the OEM steel wheels hub centric? I am thinking of going with steels (cheaper and I think classier option) to replace my aftermarket EMPI 8-spoke wheels which are difficult to balance and "center" on my hubs (1974). I have tried the EMPI cone lug bolts (using the recommended sequential "star" pattern tightening technique) as well without luck. The tire center has tried rebalancing three times now using their Hunter machine. They said wheels are straight. The tires are all new. Alternatively, they recommended custom hub centering rings since they think the EMPI's are not sitting center on the hub.
JamesM |
Oct 15 2019, 10:47 AM
Senior Member Group: Members Posts: 1,915 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Are the OEM steel wheels hub centric? I am thinking of going with steels (cheaper and I think classier option) to replace my aftermarket EMPI 8-spoke wheels which are difficult to balance and "center" on my hubs (1974). I have tried the EMPI cone lug bolts (using the recommended sequential "star" pattern tightening technique) as well without luck. The tire center has tried rebalancing three times now using their Hunter machine. They said wheels are straight. The tires are all new. Alternatively, they recommended custom hub centering rings since they think the EMPI's are not sitting center on the hub. While the later 73-76 front hubs do have a center ring, I dont know if I would consider them "hub centric" it helps but the wheels will still center on the conned lug bolts once tightened. In addition no rears ever had a centering ring. If the tire shop is balancing based on the center hole in your empis you may have an issue if that hole isnt perfectly centered. Are you having an issue with one wheel or all four? |
Lo-Fi Version | Time is now: 7th June 2024 - 04:35 PM |
