Another GB trunk hinge bolts (all 4) with lubrication kit, $20 + shipping replace before they break |
Mikey914 |
Oct 17 2019, 02:31 PM
The rubber man Group: Members Posts: 12,671 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The trunk hinge bolts are under constant stress, both front and rear.
Even in the closed position there is constant spring tension. Now you can replace all 4 of these bolts inexpensively. They typically go for @$10 each. We even supply the lube. Aluminum copper graphite grease If you have ever had one of these break you will note a ounce of prevention is well worth avoiding the ensuing hassle. So who's in ? Attached thumbnail(s) |
Mikey914 |
Oct 17 2019, 03:38 PM
The spring will need to be disconnected, but pretty sure you could do one at a time much easier.
Lo-Fi Version | Time is now: 28th May 2024 - 09:59 PM |
