2056'ers Running External Oil Cooler, Are you running one? |
BeatNavy |
Oct 17 2019, 04:02 PM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
I'm several weeks into breaking in a 2056 rebuild I did last winter. Basic specs:
1. 8.6 CR 2. 9950 Raby Cam 3. Len Hoffman built AA 2.0 heads 4. D-Jet 5. 123 Disitributor I am surprised how challenging it has been to "dial this in" to optimal. I had to dial back the timing to about 26 to eliminate some pre-ignition (even with 89 octane and cooler range spark plugs), but now the engine itself is a blast. At one point I couldn't figure out why my head temps were running above 350 and oil temps hit 270 ( (IMG:style_emoticons/default/yikes.gif) ) until I finally found the paper towel that got wedged underneath the impeller, upsetting the air flow ( (IMG:style_emoticons/default/headbang.gif) ). After fixing that fubar, I'm running amazingly cool head temps (e.g., 270 cruising at 60 in 4th gear), but my oil still wants to creep up higher than I'd like. As an example, today I did 20 minutes of spirited driving with ambient temps around 60 and oil was 210+. I am running without the engine lid right now, so I don't know if that's impacting both head and oil temps. I'm also pretty sure cooling flaps are working right, and I hope nothing else is fouling the air flow/cooling. SO, to my original question: how many of you 2056-'ers are running external oil temps (and what oil temp were you running prior)? I'm going to buy a Setrab oil cooler in any event, as I have a 2.3 waiting for install later this year, but I'm trying to determine if something else is going on with my timing/tuning/oil cooling or if it's not completely unusual for 2056 to need one. Thanks for any input (IMG:style_emoticons/default/popcorn[1].gif) |
colingreene |
Oct 17 2019, 06:12 PM
Senior Member Group: Members Posts: 729 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
I have a 2258, it would regularly get to 240 just driving around here in southern california.
That made me a bit uncomfortable. so I decided it needed a cooler, hottest ive seen it get since i put a cooler (with fan) was about 205. Car runs much more consistently now. |
Lo-Fi Version | Time is now: 2nd June 2024 - 02:30 AM |
