2056'ers Running External Oil Cooler, Are you running one? |
BeatNavy |
Oct 17 2019, 04:02 PM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
I'm several weeks into breaking in a 2056 rebuild I did last winter. Basic specs:
1. 8.6 CR 2. 9950 Raby Cam 3. Len Hoffman built AA 2.0 heads 4. D-Jet 5. 123 Disitributor I am surprised how challenging it has been to "dial this in" to optimal. I had to dial back the timing to about 26 to eliminate some pre-ignition (even with 89 octane and cooler range spark plugs), but now the engine itself is a blast. At one point I couldn't figure out why my head temps were running above 350 and oil temps hit 270 ( (IMG:style_emoticons/default/yikes.gif) ) until I finally found the paper towel that got wedged underneath the impeller, upsetting the air flow ( (IMG:style_emoticons/default/headbang.gif) ). After fixing that fubar, I'm running amazingly cool head temps (e.g., 270 cruising at 60 in 4th gear), but my oil still wants to creep up higher than I'd like. As an example, today I did 20 minutes of spirited driving with ambient temps around 60 and oil was 210+. I am running without the engine lid right now, so I don't know if that's impacting both head and oil temps. I'm also pretty sure cooling flaps are working right, and I hope nothing else is fouling the air flow/cooling. SO, to my original question: how many of you 2056-'ers are running external oil temps (and what oil temp were you running prior)? I'm going to buy a Setrab oil cooler in any event, as I have a 2.3 waiting for install later this year, but I'm trying to determine if something else is going on with my timing/tuning/oil cooling or if it's not completely unusual for 2056 to need one. Thanks for any input (IMG:style_emoticons/default/popcorn[1].gif) |
VaccaRabite |
Oct 18 2019, 10:26 AM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I have a cooler under the rear trunk on my 2056. Works great, but I don't know that I need it any more. I added it before the car was using EFI and the oil temps ran 240-250, and my head temps were always hot too.
Now that I'm on EFI my head temps are great, and its possible I no longer need the oil cooler. But I'm not interested in undoing all the plumbing to find out. With the cooler my oil temps stay between 190 and 215. Zach |
ndfrigi |
Oct 18 2019, 11:16 AM
Advanced Member Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
I have a cooler under the rear trunk on my 2056. Works great, but I don't know that I need it any more. I added it before the car was using EFI and the oil temps ran 240-250, and my head temps were always hot too. Now that I'm on EFI my head temps are great, and its possible I no longer need the oil cooler. But I'm not interested in undoing all the plumbing to find out. With the cooler my oil temps stay between 190 and 215. Zach Hello Zach, do you mind showing some pics of your cooler set up? thanks! |
Lo-Fi Version | Time is now: 9th June 2024 - 06:48 PM |
