| DRPHIL914 |
Oct 6 2019, 09:11 AM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,971 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
After returning from Okteenerfest the car sat a couple weeks, and after taking it to Cars and coffee I parked it again but backed in and a few days later pulled out and noticed 2 small puddles , front at rear- cleaned it up them parked the car , then a few days later checked again and it’s for sure under front.
I was initially worried that I had a front crank seal when I thought it was from the back, and I am releaved that it’s not from the motor, I did all that last year and am proud to say it’s been a leak free motor since then, and I didn’t want to pull the motor or trans. BUT this is brake fluid, and I can’t really explain why this would suddenly spring A leak (IMG:style_emoticons/default/confused24.gif) . I replaced all brake lines and the 19mm master cylinder about 3-4 years ago, no leaks no issues since then. And I don’t have loss of pressure on brakes so I am assuming it’s the supply line so I guess I will be pulling the belly pan to investigate. Will post more info when I get a look just wonder why just now? I know the washer is there under the supply line connection, just weird this started now??? Phil |
| Mikey914 |
Oct 18 2019, 12:36 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,786 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Interesting,
We could on the next run do up extra parts and make rebuild kits for MUCH less. (IMG:style_emoticons/default/idea.gif) |
DRPHIL914 Fluid on the floor: What could it be? Oct 6 2019, 09:11 AM
bbrock What MC did you install? There were a small numbe... Oct 6 2019, 09:43 AM
DRPHIL914
What MC did you install? There were a small numb... Oct 6 2019, 09:49 AM
76-914 Is there any fluid inside on the floorboard? Oct 6 2019, 09:50 AM
DRPHIL914
Not... Oct 6 2019, 09:53 AM
DRPHIL914
Aft... Oct 8 2019, 07:06 PM
76-914 Just see if it is on the floorboard. If so, a cup ... Oct 6 2019, 10:00 AM
rjames Someone else can correct me if I’ve got this wro... Oct 6 2019, 04:26 PM
DRPHIL914 So last night pulled carpet and took a look under ... Oct 8 2019, 07:41 AM
bdstone914 @[url=http://www.914world.com/bbs2/index.php?showu... Oct 8 2019, 08:02 AM
mepstein Phillip - did you install the metal washers under ... Oct 8 2019, 08:06 AM
DRPHIL914
Phillip - did you install the metal washers under... Oct 8 2019, 09:09 AM
rjames
Phillip - did you install the metal washers unde... Oct 8 2019, 10:50 AM
DRPHIL914
[quote name='DRPHIL914' post='2753129' date='Oct ... Oct 8 2019, 07:24 PM
bdstone914
[quote name='DRPHIL914' post='2753129' date='Oct... Oct 8 2019, 09:46 PM
DRPHIL914 Outside under MC and on top are dry, just wet at w... Oct 8 2019, 07:22 PM
mepstein I'm certainly no expert but it sounds like it ... Oct 8 2019, 07:30 PM
DRPHIL914 Has anyone installed one of the MC from 914rubber?... Oct 8 2019, 08:49 PM
Has anyone installed one of the MC from 914rubber... Oct 8 2019, 09:23 PM
Mikey914 I few have Ian made a video. Spend the extra coupl... Oct 8 2019, 09:08 PM
Mikey914 No fluid on the bottom of the cylinder is indicati... Oct 8 2019, 10:38 PM
DRPHIL914
No fluid on the bottom of the cylinder is indicat... Oct 9 2019, 07:11 AM
DRPHIL914
No fluid on the bottom of the cylinder is indicat... Oct 9 2019, 08:02 AM
Mikey914
No fluid on the bottom of the cylinder is indica... Oct 10 2019, 03:27 PM
DRPHIL914
[quote name='DRPHIL914' post='2753392' date='Oct ... Oct 16 2019, 06:21 AM
dr914@autoatlanta.com yes master cylinder has failed. As much trouble as... Oct 9 2019, 08:31 AM
DRPHIL914
yes master cylinder has failed. As much trouble a... Oct 9 2019, 09:26 AM
DRPHIL914 I did get this project partly completed last night... Oct 18 2019, 07:10 AM
Mikey914 Yes, mush easier job on a rack, If you need new li... Oct 18 2019, 09:24 AM
Mikey914 Also,
On the old one after yo get this done. Can y... Oct 18 2019, 09:27 AM
DRPHIL914
Also,
On the old one after yo get this done. Can ... Oct 18 2019, 09:39 AM
DRPHIL914 I would assume this could be rebuilt and a new sea... Oct 18 2019, 09:40 AM
76-914
I would assume this could be rebuilt and a new se... Oct 18 2019, 10:19 AM
Mikey914
I would assume this could be rebuilt and a new se... Oct 18 2019, 10:30 AM
malcolm2 Google.... Or I used duck duck go now, but search ... Oct 18 2019, 10:46 AM
DRPHIL914
Google.... Or I used duck duck go now, but search... Oct 18 2019, 01:16 PM
malcolm2
Interesting,
We could on the next run do up extra... Oct 18 2019, 01:46 PM
IronHillRestorations I have a 1500 mile master cylinder that needs a se... Oct 18 2019, 01:41 PM
DRPHIL914 5 hours , MC in, pedals removed floor and pedal cl... Oct 19 2019, 04:12 PM
DRPHIL914 Here is the MC that came out , leaking from front ... Oct 19 2019, 06:14 PM
DRPHIL914 Another view
I will probably order a rebuild kit ... Oct 19 2019, 06:17 PM
Mikey914 Drop me a call tomorrow. You do want to put the ab... Oct 19 2019, 11:13 PM
DRPHIL914
Drop me a call tomorrow. You do want to put the a... Oct 19 2019, 11:42 PM
DRPHIL914 Spoke with Mark and we are pretty sure the wrong o... Oct 22 2019, 07:06 AM![]() ![]() |
Lo-Fi Version | Time is now: 3rd November 2026 - 02:05 PM |
