> Fluid on the floor: What could it be?, (time to take a brake?)Slight mystery upon returning from Okteenerfest
DRPHIL914
post Oct 6 2019, 09:11 AM
Dr. Phil
After returning from Okteenerfest the car sat a couple weeks, and after taking it to Cars and coffee I parked it again but backed in and a few days later pulled out and noticed 2 small puddles , front at rear- cleaned it up them parked the car , then a few days later checked again and it’s for sure under front.
I was initially worried that I had a front crank seal when I thought it was from the back, and I am releaved that it’s not from the motor,
I did all that last year and am proud to say it’s been a leak free motor since then, and I didn’t want to pull the motor or trans.
BUT this is brake fluid, and I can’t really explain why this would suddenly spring
A leak (IMG:style_emoticons/default/confused24.gif) . I replaced all brake lines and the 19mm master cylinder about 3-4 years ago, no leaks no issues since then.
And I don’t have loss of pressure on brakes so I am assuming it’s the supply line so I guess I will be pulling the belly pan to investigate. Will post more info when I get a look just wonder why just now? I know the washer is there under the supply line connection, just weird this started now???
Phil
malcolm2
post Oct 18 2019, 10:46 AM
Google.... Or I used duck duck go now, but search for 911 master cylinder rebuild kit. tons of them. surprised we haven't gotten the "it's your safety" comment. But it would be nice to have one on the shelf for next time.
95$ here:https://www.aasesales.com/products/da3c-b52...e4626&_ss=r
DRPHIL914
post Oct 18 2019, 01:16 PM
Dr. Phil
QUOTE(malcolm2 @ Oct 18 2019, 12:46 PM) *
I started to google that right after posting that but did run across Pelican and Stoddards , some sites I cant access here at work, so I have to wait until I get home, but it did seem a bit pricy for what you are looking at to rebuild these.
its interesting that my first MC failure had no leaking but internally no longer was able to hold pressure, and I think this is the most common failure.
This one failed by leaking out with out actually loosing any pressure or braking function so I didn't have a clue it was happening until the big puddle appeared in the garage floor.
- pictures tonight!
Mark, if you do a rebuild kit I would think this would pay off over time .
I have no idea where the parts in these other kits are sourced from in other words, where are they and by whom are they manufactured? AASE, Stoddard, Pelican, and AA have the kits but who makes the components?
I would like to rebuild this one that failed and have one on the shelf just in case of future failure of this new unit I am installing.
DRPHIL914   Fluid on the floor: What could it be?   Oct 6 2019, 09:11 AM
bbrock   What MC did you install? There were a small numbe...   Oct 6 2019, 09:43 AM
DRPHIL914   What MC did you install? There were a small numb...   Oct 6 2019, 09:49 AM
76-914   Is there any fluid inside on the floorboard?   Oct 6 2019, 09:50 AM
DRPHIL914   Is there any fluid inside on the floorboard? Not...   Oct 6 2019, 09:53 AM
DRPHIL914   Is there any fluid inside on the floorboard? Aft...   Oct 8 2019, 07:06 PM
76-914   Just see if it is on the floorboard. If so, a cup ...   Oct 6 2019, 10:00 AM
rjames   Someone else can correct me if I’ve got this wro...   Oct 6 2019, 04:26 PM
DRPHIL914   So last night pulled carpet and took a look under ...   Oct 8 2019, 07:41 AM
bdstone914   @[url=http://www.914world.com/bbs2/index.php?showu...   Oct 8 2019, 08:02 AM
mepstein   Phillip - did you install the metal washers under ...   Oct 8 2019, 08:06 AM
DRPHIL914   Phillip - did you install the metal washers under...   Oct 8 2019, 09:09 AM
rjames   Phillip - did you install the metal washers unde...   Oct 8 2019, 10:50 AM
DRPHIL914   [quote name='DRPHIL914' post='2753129' date='Oct ...   Oct 8 2019, 07:24 PM
bdstone914   [quote name='DRPHIL914' post='2753129' date='Oct...   Oct 8 2019, 09:46 PM
DRPHIL914   Outside under MC and on top are dry, just wet at w...   Oct 8 2019, 07:22 PM
mepstein   I'm certainly no expert but it sounds like it ...   Oct 8 2019, 07:30 PM
DRPHIL914   Has anyone installed one of the MC from 914rubber?...   Oct 8 2019, 08:49 PM
mepstein   Has anyone installed one of the MC from 914rubber...   Oct 8 2019, 09:23 PM
Mikey914   I few have Ian made a video. Spend the extra coupl...   Oct 8 2019, 09:08 PM
Mikey914   No fluid on the bottom of the cylinder is indicati...   Oct 8 2019, 10:38 PM
DRPHIL914   No fluid on the bottom of the cylinder is indicat...   Oct 9 2019, 07:11 AM
DRPHIL914   No fluid on the bottom of the cylinder is indicat...   Oct 9 2019, 08:02 AM
Mikey914   No fluid on the bottom of the cylinder is indica...   Oct 10 2019, 03:27 PM
DRPHIL914   [quote name='DRPHIL914' post='2753392' date='Oct ...   Oct 16 2019, 06:21 AM
dr914@autoatlanta.com   yes master cylinder has failed. As much trouble as...   Oct 9 2019, 08:31 AM
DRPHIL914   yes master cylinder has failed. As much trouble a...   Oct 9 2019, 09:26 AM
DRPHIL914   I did get this project partly completed last night...   Oct 18 2019, 07:10 AM
Mikey914   Yes, mush easier job on a rack, If you need new li...   Oct 18 2019, 09:24 AM
Mikey914   Also, On the old one after yo get this done. Can y...   Oct 18 2019, 09:27 AM
DRPHIL914   Also, On the old one after yo get this done. Can ...   Oct 18 2019, 09:39 AM
DRPHIL914   I would assume this could be rebuilt and a new sea...   Oct 18 2019, 09:40 AM
76-914   I would assume this could be rebuilt and a new se...   Oct 18 2019, 10:19 AM
Mikey914   I would assume this could be rebuilt and a new se...   Oct 18 2019, 10:30 AM
malcolm2   Google.... Or I used duck duck go now, but search ...   Oct 18 2019, 10:46 AM
DRPHIL914   Google.... Or I used duck duck go now, but search...   Oct 18 2019, 01:16 PM
Mikey914   Interesting, We could on the next run do up extra ...   Oct 18 2019, 12:36 PM
malcolm2   Interesting, We could on the next run do up extra...   Oct 18 2019, 01:46 PM
IronHillRestorations   I have a 1500 mile master cylinder that needs a se...   Oct 18 2019, 01:41 PM
DRPHIL914   5 hours , MC in, pedals removed floor and pedal cl...   Oct 19 2019, 04:12 PM
DRPHIL914   Here is the MC that came out , leaking from front ...   Oct 19 2019, 06:14 PM
DRPHIL914   Another view I will probably order a rebuild kit ...   Oct 19 2019, 06:17 PM
Mikey914   Drop me a call tomorrow. You do want to put the ab...   Oct 19 2019, 11:13 PM
DRPHIL914   Drop me a call tomorrow. You do want to put the a...   Oct 19 2019, 11:42 PM
DRPHIL914   Spoke with Mark and we are pretty sure the wrong o...   Oct 22 2019, 07:06 AM
- Lo-Fi Version Time is now: 3rd November 2026 - 02:05 PM
