Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
So, I put the new alternator in and install the fan back in it's housing. Fan spins free with no issues.
Then I put it in the shroud and tighten up the strap around the alt stand. When I run the motor it makes a horrid scraping sound and metal shavings are a flying. (IMG:style_emoticons/default/headbang.gif) Why? Help me. KT |
DonTraver |
Senior Member ![]() ![]() ![]() Group: Members Posts: 829 Joined: 5-August 04 Member No.: 2,461 ![]() |
Pull it out again, I know, damn. Look for the slot on the outside of the fan housing. Check for the roll pin in the engine case. Mark the housing with a magic marker 180 degrees from the slot, the mark will be on the top of the housing when it's installed right. Put the alternator back in, wiggle it onto the pin. Install the strap, and test run.
Lo-Fi Version | Time is now: 3rd July 2025 - 01:50 PM |
