Reverse Lights |
Reverse Lights |
ballsyfacts914 |
Oct 19 2019, 02:05 PM
Member Group: Members Posts: 82 Joined: 28-August 19 From: East Bay Region-SF Bay Area Member No.: 23,413 Region Association: Northern California |
Hi All! Reverse lights don't work, bulbs changed...check. Connections all there...check. Even checked the battery and followed the wires into the engine compartment and don't see any missed connections.
Any suggestions? Thanks |
lierofox |
Oct 19 2019, 02:17 PM
Member Group: Members Posts: 256 Joined: 23-June 15 From: Paso Robles, CA Member No.: 18,880 Region Association: Southern California |
Is the reverse switch on the transmission plugged in as well? 2 small round bullet connectors plug into it under a rubber boot. Double check to make sure voltage is making its way through the engine compartment relay board as well.
The full path of the reverse light circuit: It starts out by teeing off from the brake light switch (gray/brown wires) from there it travels to the engine bay relay board through the 14 pin connector (Pin 3), it goes through the relay board, out the 12 pin connector (Pin 2), down to the transmission to the reverse switch, back up to the 12 pin connector (Pin 4), back through the relay board, and then back out of the 14 pin connector (Pin 4), and finally out to the reverse lights. In all cases the wires for the reverse light circuit are the same color, gray with brown stripe. |
Lo-Fi Version | Time is now: 11th June 2024 - 07:43 AM |
