Reverse Lights |
Reverse Lights |
ballsyfacts914 |
Oct 19 2019, 02:05 PM
Member Group: Members Posts: 82 Joined: 28-August 19 From: East Bay Region-SF Bay Area Member No.: 23,413 Region Association: Northern California |
Hi All! Reverse lights don't work, bulbs changed...check. Connections all there...check. Even checked the battery and followed the wires into the engine compartment and don't see any missed connections.
Any suggestions? Thanks |
ballsyfacts914 |
Oct 19 2019, 02:31 PM
Starting to figure it is the pin, what page in Haynes? Or pictures.
Thanks |
Jonathan Livesay |
Oct 19 2019, 02:40 PM
Senior Member Group: Members Posts: 742 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
Starting to figure it is the pin, what page in Haynes? Or pictures. Thanks If there is a pin present then it's not that. You can check the switch after verifying that the pin is present by pulling the 2 wires out of the switch and putting an ohm meter across the terminals, if it doesn't drop to zero ohms when you shift into reverse then the switch is bad. |
DickSteinkamp |
Oct 19 2019, 03:16 PM
Senior Member Group: Members Posts: 500 Joined: 27-February 17 From: Bellingham, WA Member No.: 20,876 Region Association: None |
If there is a pin present then it's not that. You can check the switch after verifying that the pin is present by pulling the 2 wires out of the switch and putting an ohm meter across the terminals, if it doesn't drop to zero ohms when you shift into reverse then the switch is bad. ...or you can just unplug and jumper the two wires that plug into the back up light switch and shift into reverse with the key on. If the back up lights work, it's the switch. |
Jonathan Livesay |
Oct 19 2019, 04:39 PM
If there is a pin present then it's not that. You can check the switch after verifying that the pin is present by pulling the 2 wires out of the switch and putting an ohm meter across the terminals, if it doesn't drop to zero ohms when you shift into reverse then the switch is bad. ...or you can just unplug and jumper the two wires that plug into the back up light switch and shift into reverse with the key on. If the back up lights work, it's the switch. The backup lights will be on in any gear or neutral with the key on if you jump those two wires, since you have removed the switch from the equation. But that is a good way to make sure everything else is working. |
Lo-Fi Version | Time is now: 10th June 2024 - 09:31 PM |
