| Michael J |
Dec 4 2004, 10:58 AM
Welcome to 2007 ![]() ![]() Group: Members Posts: 268 Joined: 23-November 04 From: Olympia, WA Member No.: 3,166 |
Have had my 914 for a couple of weeks now. It's a stock 1.7. It's in the garage getting a few little details taken care of but I need your collective wisdom. The car starts at the touch of the key. It idles at about 2 grand and once its' warm and I drive off it surges all the time. The car has sat for quite a while so I put fresh gas in and some gas dryer. The PO says it ran ok a couple of years ago. He had 18 cars and probably didn't pay much attention. I have been checking all the vacum hoses and they look ok but can't tell for sure if there are leaks.
Your Thoughts? Mike '72 adriatic blue 1.7 - my one and only |
| DJsRepS |
Dec 5 2004, 07:22 AM
Member ![]() ![]() Group: Members Posts: 431 Joined: 4-November 04 From: Sarasota Florida Member No.: 3,060 |
New gas lines asap, adj valves, clean and lube trigger points, new ign points and condenser, set dwell then timing, Vaccume/Breather/PVC all hooked up tight, Vacuume check MPS mainfold pressuer sensor, the AAR valve can be capped off for testing hell I guess Im still testing mine everyday as its in the trunk. That's enough to keep someone going a while. None of the above may fix the problem but it sure wont hurt anything!!
Michael J A '72 Djet question Dec 4 2004, 10:58 AM
vsg914 Welcome to the club, Michael.
Idleing cold at 2K ... Dec 4 2004, 11:13 AM
Rhodes71/914 You said that it sat for a few years, this prolly ... Dec 4 2004, 12:00 PM
Michael J I know it's hard to do any diagnosis this way ... Dec 4 2004, 12:02 PM
Bleyseng :agree:
Change the damn fuel lines in the engine ... Dec 4 2004, 12:20 PM
vsg914 another piece of the puzzle emerges. Geoff is righ... Dec 4 2004, 01:12 PM
SirAndy ... Dec 4 2004, 01:46 PM
Rhodes71/914 Yeah what Andy said.
Mine had a similar problem a... Dec 4 2004, 09:32 PM
Deano If you really suspect the TPS, do what I did, I to... Dec 4 2004, 10:36 PM
michelko Don“t know much about your problem, but nice to s... Dec 5 2004, 12:47 PM
JOHNMAN ![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:01 PM |
