| Michael J |
Dec 4 2004, 10:58 AM
Welcome to 2007 ![]() ![]() Group: Members Posts: 268 Joined: 23-November 04 From: Olympia, WA Member No.: 3,166 |
Have had my 914 for a couple of weeks now. It's a stock 1.7. It's in the garage getting a few little details taken care of but I need your collective wisdom. The car starts at the touch of the key. It idles at about 2 grand and once its' warm and I drive off it surges all the time. The car has sat for quite a while so I put fresh gas in and some gas dryer. The PO says it ran ok a couple of years ago. He had 18 cars and probably didn't pay much attention. I have been checking all the vacum hoses and they look ok but can't tell for sure if there are leaks.
Your Thoughts? Mike '72 adriatic blue 1.7 - my one and only |
| John |
Dec 5 2004, 01:22 PM
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
QUOTE If you really suspect the TPS, do what I did, I took it apart and very carefully cleaned the contact points. I used a little denatured alcohol on a Q-tip. It took care of my hesitation problem. You could also simply UNPLUG the TPS and see if the surging stops. The car won't accelerate quite as well without the TPS as it enrichens the mixture (adds pulses of fuel to the injectors), but it will run. My thoughts are that you have some big air leaks (that you need to fix) and the car is having lean surging. If this is the case, when you fix the air leaks the surging will stop. |
Michael J A '72 Djet question Dec 4 2004, 10:58 AM
vsg914 Welcome to the club, Michael.
Idleing cold at 2K ... Dec 4 2004, 11:13 AM
Rhodes71/914 You said that it sat for a few years, this prolly ... Dec 4 2004, 12:00 PM
Michael J I know it's hard to do any diagnosis this way ... Dec 4 2004, 12:02 PM
Bleyseng :agree:
Change the damn fuel lines in the engine ... Dec 4 2004, 12:20 PM
vsg914 another piece of the puzzle emerges. Geoff is righ... Dec 4 2004, 01:12 PM
SirAndy ... Dec 4 2004, 01:46 PM
Rhodes71/914 Yeah what Andy said.
Mine had a similar problem a... Dec 4 2004, 09:32 PM
Deano If you really suspect the TPS, do what I did, I to... Dec 4 2004, 10:36 PM
DJsRepS New gas lines asap, adj valves, clean and lube tri... Dec 5 2004, 07:22 AM
michelko Don“t know much about your problem, but nice to s... Dec 5 2004, 12:47 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:42 PM |
