threw another #3 rod, how to prevent this from happening again. |
crash914 |
Oct 29 2019, 03:17 PM
its a mystery to me Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
So blew up my #3 rod. wondering what caused this. lack of oil, due to rpm? poor return? oil pump sucking air?
last time it was #2 rod. I really don't want to live with this again. Motor specs, Dual oil coolers with full flow plumbing 102 bore by 80mm stroke long rods, ham heads and valve train. Running to 6800 rpm g loads to 1.5 windage tray modified at pushrod tubes for oil flow tuna can with 1/2 extra oil Pics of horror below. First are this failure, then old failure. |
yeahmag |
Oct 30 2019, 09:30 PM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
I had to rebuild two motors before switching to a dry sump due to rod knock. The CB Performance pump has pretty poor idle pressure, but is fine at anything about 1200 RPM. I did do a bit of work to open the ports in it...
Evan and I beat the piss out of the motor now (7000-7250 RPM) and it doesn't bat an eye. |
Lo-Fi Version | Time is now: 1st June 2024 - 06:23 PM |
