| tvdinnerbythepool |
Oct 9 2019, 10:55 AM
Member ![]() ![]() Group: Members Posts: 310 Joined: 24-July 18 From: Olympia, WA Member No.: 22,336 Region Association: Pacific Northwest
Back is done, on to the front (later in this thread)
Hey guys, Starting winter projects: Rear Brakes/Suspension are up first. -This is a street/daily driver. Just trying to get the sagging ass up and improve the ride quality. - So far I've got New: 100lb 914rubber upper and lower shock rubber bushings Plan is to buy: Rear control arm bushings (914Rubber) Rear Caliper Rebuild Kit (If that seems beyond me I will send to PMB) Discs and Pads will be addressed as needed once I get it all apart. Turn the discs if needed or replace with new pads. We shall see. Any suggestions on anything else with the rear brakes/suspension?? Thanks all! -Rob Front Suspension/Brakes will be part 2 of the project. Just trying to keep it manageable and on budget ish |
| Tdskip |
Oct 31 2019, 10:12 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,783 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
It will be. Like all vintage German cars 914s respond very well to good parts and attention to detail.
tvdinnerbythepool Suspension and Brake Refresh Oct 9 2019, 10:55 AM
mepstein Just say NO to KYB struts. Spend the money on Bils... Oct 9 2019, 11:01 AM
SirAndy Just say NO to KYB struts
:agree: Oct 9 2019, 12:02 PM
914_teener Hope your budget is $1800.
Might as well do... Oct 9 2019, 11:51 AM
Tbrown4x4 PMB is the benchmark for caliper rebuilds, but I h... Oct 9 2019, 05:13 PM
rhodyguy Better off spending more now rather than might bei... Oct 9 2019, 05:31 PM
roblav1 As others said, don't use KYB. Oct 9 2019, 06:23 PM
914Sixer KYB= Kill Your Back. If you want to feel every pe... Oct 10 2019, 04:22 AM
tvdinnerbythepool Awesome, thanks for the input guys.
Sounds like K... Oct 10 2019, 07:40 AM
tvdinnerbythepool @Tbrown4x4 did I see you by the Olympia airport a... Oct 10 2019, 07:41 AM
Tbrown4x4 I was down that way for a wedding , but we took th... Oct 11 2019, 04:54 AM
tvdinnerbythepool Hey guys!
I've seen a few methods online b... Oct 24 2019, 10:24 PM
Hey guys!
I've seen a few methods online ... Oct 25 2019, 06:13 AM
914werke From that pic it looks like you may have more work... Oct 25 2019, 12:24 AM
Tbrown4x4 I'm reading that you are blasting the calipers... Oct 25 2019, 05:01 AM
tvdinnerbythepool @914werke for sure! It was a ton of work just... Oct 25 2019, 09:59 AM
tvdinnerbythepool 1 down! Took about 40 minutes with heat and pr... Oct 25 2019, 10:49 AM
TonyA Like that operating room clean look of your shop.... Oct 25 2019, 01:31 PM
mepstein Mine took 5-10 minutes each side but I really laid... Oct 25 2019, 11:17 AM
914werke :( Mmmm IDK... I chuck them up in the lathe ... Oct 25 2019, 11:42 AM
tvdinnerbythepool Calipers stripped, blasted and painted.
Will repo... Oct 31 2019, 08:14 AM
tvdinnerbythepool RE: Suspension and Brake Refresh Oct 31 2019, 10:28 AM
tvdinnerbythepool RE: Suspension and Brake Refresh Oct 31 2019, 10:29 AM
tvdinnerbythepool RE: Suspension and Brake Refresh Oct 31 2019, 10:30 AM
DucRS Calipers are looking good!
Please chime in o... Oct 31 2019, 11:10 AM
mepstein Here’s Eric’s /PMB Performance video for rebui... Oct 31 2019, 11:18 AM
tvdinnerbythepool @ducrs I followed the pelican disassembly article... Nov 1 2019, 07:30 AM
mepstein I’m pretty sure all the calipers had nuts for th... Nov 1 2019, 07:34 AM
tvdinnerbythepool
I’m pretty sure all the calipers had nuts for t... Nov 1 2019, 07:45 AM
[quote name='mepstein' post='2758729' date='Nov 1... Nov 1 2019, 07:55 AM
bbrock
I’m pretty sure all the calipers had nuts for t... Nov 1 2019, 08:00 AM
[quote name='mepstein' post='2758729' date='Nov 1... Nov 1 2019, 08:48 AM
tvdinnerbythepool
Drivers side sans nuts Nov 1 2019, 07:46 AM
tvdinnerbythepool Drivers side caliper rebuilt!
Still sourcing b... Nov 5 2019, 07:46 PM
eatpez
Still sourcing ... Nov 5 2019, 08:00 PM
Tbrown4x4 Yes, those look great! Nov 5 2019, 09:34 PM
914werke Shafted! Nov 7 2019, 02:14 PM
TargaToy
Shafted!
I've been curious, since you m... Nov 15 2019, 02:32 PM
tvdinnerbythepool
914Rubber 100lb Springs on Bilsteins :headbang... Nov 13 2019, 09:45 AM
914Rubber 100lb Springs on Bilsteins :headban... Nov 13 2019, 10:27 AM
tvdinnerbythepool
914Rubber 100lb Springs on Bilsteins :headba... Nov 13 2019, 11:29 AM
type2man If you already have the rear arms out, I would def... Nov 13 2019, 06:26 PM
tvdinnerbythepool
Bearings are in! Going to make a threaded to... Nov 14 2019, 11:11 PM
tvdinnerbythepool Maybe a stupid question...how do I know when the h... Nov 15 2019, 11:55 AM
tvdinnerbythepool Should the hub shaft be flush with bearing?? Nov 15 2019, 11:56 AM
Tbrown4x4 The shoulder on the hub will bottom out on the inn... Nov 15 2019, 01:14 PM
914werke If you look at the process for installing either t... Nov 15 2019, 03:35 PM
TargaToy
If you look at the process for installing either ... Nov 15 2019, 03:59 PM
Mikey914 Actually when Elephant made their rods they used a... Nov 15 2019, 06:19 PM
914werke Actually when Elephant made their rods they used ... Nov 16 2019, 12:21 AM
Mikey914
Actually when Elephant made their rods they used... Nov 16 2019, 11:22 PM
tvdinnerbythepool Starting to see some progress and feeling like I d... Nov 16 2019, 07:05 PM
Starting to see some progress and feeling like I ... Nov 23 2019, 01:36 PM
tvdinnerbythepool
Starting to see some progress and feeling like I... Nov 23 2019, 02:07 PM
[quote name='mepstein' post='2764453' date='Nov 2... Nov 23 2019, 02:10 PM
tvdinnerbythepool @mepstein I was thinking the same thing! :co... Nov 23 2019, 03:13 PM
[b]@[url=http://www.914world.com/bbs2/index.php?s... Nov 24 2019, 12:24 PM
tvdinnerbythepool With the back pretty much wrapped up it's on t... Nov 23 2019, 12:54 PM
tvdinnerbythepool RE: Suspension and Brake Refresh Nov 23 2019, 12:54 PM
tvdinnerbythepool This was the worse of the two sides
Nov 23 2019, 12:55 PM
mepstein Heat up the fittings that hold the bushings until ... Nov 23 2019, 01:31 PM
DRPHIL914 Looks nice , did you put the spring retainer clip ... Nov 23 2019, 02:34 PM
tvdinnerbythepool @DRPHIL914 Hi! Not sure what that means...can... Nov 23 2019, 03:14 PM
DRPHIL914
[b]@[url=http://www.914world.com/bbs2/index.php?s... Nov 23 2019, 04:47 PM
tvdinnerbythepool @DRPHIL914 gotcha! Thanks for clarifying. Yes... Nov 23 2019, 05:06 PM
[b]@[url=http://www.914world.com/bbs2/index.php?s... Nov 23 2019, 05:44 PM
jmitro
There are 6 I think slots for the retainer that h... Nov 24 2019, 02:29 PM
DRPHIL914 Looking at the tyre size charts for comparison my
... Nov 23 2019, 07:16 PM
tvdinnerbythepool Any one else have Rivieras that can weigh in?
@d... Nov 23 2019, 08:35 PM
DRPHIL914
[... Nov 24 2019, 06:35 AM
tvdinnerbythepool
Holy cow! That was stressful!
Not sure ... Dec 1 2019, 10:43 AM
cuddy_k
Not sure h... Dec 2 2019, 09:58 PM
tvdinnerbythepool Stupid question for the night. Bilsteins going up ... Dec 2 2019, 09:40 PM
Stupid question for the night. Bilsteins going up... Dec 2 2019, 10:15 PM
tvdinnerbythepool And while I'm asking...Torsion Bars!
L fo... Dec 2 2019, 09:43 PM
L f... Dec 2 2019, 10:15 PM
bbrock
L f... Dec 3 2019, 08:55 AM
tvdinnerbythepool Thank you! @mepstein and [b]@[url=http://ww... Dec 3 2019, 08:10 AM
tvdinnerbythepool Making slow progress on the front rebuild.
Rebui... Dec 18 2019, 10:34 PM
Mikey914
Rebu... Dec 19 2019, 01:50 PM
maf914 Very nice looking work!
Make sure the O-rings... Dec 19 2019, 07:16 AM
tvdinnerbythepool Thanks @mikey914 text with specs sent
Can someo... Dec 19 2019, 08:16 PM
bbrock
Thanks [b]@[url=http://www.914world.com/bbs2/ind... Dec 20 2019, 12:50 AM
rgalla9146 If doing both calipers at the same time be sure to... Dec 20 2019, 07:23 AM
tvdinnerbythepool Thanks guys, trying to wrap my mind around it.
Fou... Dec 20 2019, 09:22 AM
tvdinnerbythepool Did a test fit just to make sure I had it oriented... Dec 21 2019, 02:39 PM
tvdinnerbythepool New discs and bearings are in!
Followed Ian... Dec 21 2019, 02:40 PM
tvdinnerbythepool This car is like the most frustrating game of Whac... Jan 5 2020, 06:44 PM
DickSteinkamp
What do you guys think? Am I missing anything e... Jan 5 2020, 07:44 PM
ndfrigi with 195x60 tires, it should not be that close to ... Jan 5 2020, 07:23 PM
mepstein It’s the Rivs. That’s a wide tire for them but... Jan 5 2020, 07:41 PM
tvdinnerbythepool Here is a side view pic. The ride height is too hi... Jan 5 2020, 08:14 PM
ndfrigi
Here is a side view pic. The ride height is too h... Jan 5 2020, 09:37 PM
raynekat
Here is a side view pic. The ride height is too ... Jan 5 2020, 09:45 PM
tvdinnerbythepool RE: Suspension and Brake Refresh Jan 5 2020, 08:15 PM
rhodyguy Have you settled the suspension? You need to roll ... Jan 5 2020, 08:19 PM
tvdinnerbythepool
Have you settled the suspension? You need to roll... Jan 5 2020, 08:25 PM
mepstein The type of wheel won’t make a difference. They ... Jan 5 2020, 08:25 PM
burton73
The type of wheel won’t make a difference. They... Jan 5 2020, 09:14 PM![]() ![]() |
Lo-Fi Version | Time is now: 28th September 2026 - 09:52 PM |
