Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,679 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
With the rash of shifting issues popping up doing a GB so you can inexpensively replace all the bushings in one shot even the cover and correct band to keep the crud out.
You will get the 1 cup bushing ( one at the transmission) the bushing at the firewall the knuckle bushing (yes set of 2) the transmission guide bushing the rubber sleeve for the rod at the transmission Option for new cover ... at $8 option for new cover band and hardware at $9 Maybe even a few other options (IMG:style_emoticons/default/biggrin.gif) You know me ..while you are there. Attached thumbnail(s) ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Tdskip |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None ![]() ![]() |
Interested and would like to take part/support you but I’m also confused as to what comes in the kit and at what cost.
Maybe group all of the bushings together with a clear price and then make add-ons optional with a price per item? Thanks! |
Mikey914 |
Interested and would like to take part/support you but I’m also confused as to what comes in the kit and at what cost. Maybe group all of the bushings together with a clear price and then make add-ons optional with a price per item? Thanks! This is the GB advertised It’s everything needed to replace all the side shift bushings. You will get the 1 cup bushing ( one at the transmission) the bushing at the firewall the knuckle bushing (yes set of 2) the transmission guide bushing the rubber sleeve for the rod at the transmission There will be options for covers, bands and even a limited number of the special shift knobs I make., or perhaps the shift knob should be stand alone. We are doing more up know. I’ll be sending PMs out Monday it’s on thanks all |
Tdskip |
Interested and would like to take part/support you but I’m also confused as to what comes in the kit and at what cost. Maybe group all of the bushings together with a clear price and then make add-ons optional with a price per item? Thanks! This is the GB advertised It’s everything needed to replace all the side shift bushings. You will get the 1 cup bushing ( one at the transmission) the bushing at the firewall the knuckle bushing (yes set of 2) the transmission guide bushing the rubber sleeve for the rod at the transmission There will be options for covers, bands and even a limited number of the special shift knobs I make., or perhaps the shift knob should be stand alone. We are doing more up know. I’ll be sending PMs out Monday it’s on thanks all @Mikey914 - thanks and I’m in. |
Lo-Fi Version | Time is now: 16th June 2024 - 12:32 PM |
