| smveril |
Nov 3 2019, 01:28 PM
Mikey ![]() ![]() Group: Members Posts: 50 Joined: 6-December 04 From: Cincinnati, OH Member No.: 3,232 Region Association: Upper MidWest |
I have a 73 2 liter that I am near the end of the restoration.
We are trying to get the car to run. The engine is rebuilt, it has a Bosley fuel injection harness. We pulled two injectors and we saw no fuel flow. The fuel pump runs and we have fuel pressure. We then removed the ECU and checked the pin outs on the ECU cable per Paul Andres schematic. One thing we found was the start signal from the ignition switch was 10.5 volts. It should be greater than 12 volts (pin 18 and ground). What could cause the low voltage to the ECU? Thanks, Mike . |
| sixnotfour |
Nov 4 2019, 04:08 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,365 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
fuel lines backwards
smveril Fuel injection not working Nov 3 2019, 01:28 PM
Bleyseng Does it start on starting fluid? Nov 4 2019, 04:02 PM
smveril It will run on starting fluiid. We did check the ... Nov 4 2019, 07:53 PM
smveril So, I am looking for ideas that restrict the ECU f... Nov 4 2019, 08:17 PM
jcd914
One thing we found was the start signal from the ... Nov 4 2019, 10:21 PM
porschetub or bad ignition switch ?????. Nov 4 2019, 11:10 PM
914_teener
I agree....or ba... Nov 5 2019, 11:04 AM
smveril The fuel pump does run. I replaced the ignition s... Nov 5 2019, 05:50 PM
914_teener
The fuel pump does run. I replaced the ignition ... Nov 5 2019, 06:20 PM
jack20 Confirm that the female trigger points plug is mak... Nov 8 2019, 12:18 AM![]() ![]() |
Lo-Fi Version | Time is now: 16th September 2026 - 01:40 AM |
