> Is this LSD ?, ... or perhaps some other phenomenae ?
drifter914
post Nov 8 2019, 10:03 AM
drifter914
So I have this '76 914-8 with an LS-1 conversion & one day while pulling out of a graveled area I kicked it a bit & noticed leaving 2 ruts behind instead of the one I was used to in a previous 914.
So the other day when I had it up on jack stands I started it up, put it in 1st gear & let it idle while I got out to look... left rear wheel was turning fwd at a constant rate, while the right was also turning fwd, but at a slower rate.
Could it be that I have some sort of limited slip arrangement here ? Transaxle is a modified 901 & has the numbers HA 22095 on the bottom of the case.
Thanks for any info on this... Terry
post Nov 8 2019, 03:33 PM
914-6 GT in waiting
Sorry, meant to say if both turn the same direction forward or backward, it’s got lsd. If they turn opposite, no lsd.
drifter914
post Nov 9 2019, 10:30 AM
drifter914
QUOTE(mepstein @ Nov 8 2019, 02:33 PM) *
O.K. ... this morning I jacked up the back end & spun the driver side rear wheel by hand... first in neutral ... then in 2nd gear same result... they turned in opposite directions... no LSD .
So the two ruts in the gravel must mean that with very little resistance, the wheels spin alternatively. I notice the right side rut is more pronounced.
I imagine on asphalt I would leave only a right tire burnout, but I just am not a burnout guy... so no LSD for me !
Terry
Superhawk996
post Nov 9 2019, 11:56 AM
QUOTE(drifter914 @ Nov 9 2019, 11:30 AM) *
Terry
The reason you see two tracks is because the road friction is reasonably uniform at each contact patch at each tire. In the case of gravel it is a medium friction surface. Friction is referred to as Mu in reference to its Greek symbol that represents the coefficient of friction in physics equations.
A conventional open differential is able to drive both wheels with approximately the same force to each wheel on medium and high Mu surfaces. For typical passenger car applications It isn't until you get onto very low mu surfaces (mud, snow, ice, etc.) that the "one wheel peel" effect of spinning up one wheel becomes a problem.
Similarly, if you are cornering hard and unloading the inside tire, that wheel can spin due to the light load on it that limits the amount of torque it can transfer to to road. An open differential can only transfer torque equally between the wheels. If one wheel is lightly loaded or on low mu (like ice), that low torque transferred is effectively zero. One wheel spins and transfers very little torque and the other wheel therefor gets zero torque, and the car doesn't move. At that point you're giving up forward momentum. LSD's are used in performance applications to help overcome this limitation of an open differential but if you lift a wheel off the road even with a LSD, you'll quickly discover that even a high bias LSD can't transfer very much torque. Better than an open differential but still not very much. Modern electronic Limited Slip Differentials would be the sole exception but those really are a completely different animal vs. a clutch plate LSD or a Torsen.
In your case, with both wheels just going straight with no cornering, the load on each is about equal. The road surface is about equal mu from side to side. The open differential transfers approximately equal torque, therefore you get approximately equal spin out marks.
drifter914   Is this LSD ?   Nov 8 2019, 10:03 AM
mepstein   Jack up the rear. Turn one wheel forward. If they ...   Nov 8 2019, 10:13 AM
Retroracer   Jack up the rear. Turn one wheel forward. If they...   Nov 8 2019, 01:54 PM
GregAmy   The car that made these two equal-length tire mark...   Nov 8 2019, 11:05 AM
burton73   My Cousin Vinny (5/5) Movie CLIP - Automotive Expe...   Nov 8 2019, 02:50 PM
mepstein   Sorry, meant to say if both turn the same directio...   Nov 8 2019, 03:33 PM
drifter914   Sorry, meant to say if both turn the same directi...   Nov 9 2019, 10:30 AM
Superhawk996   Sorry, meant to say if both turn the same direct...   Nov 9 2019, 11:56 AM
settador   Last time I had LSD I saw colors and the road wa...   Nov 9 2019, 11:19 AM
GregAmy   Last time I had LSD I saw colors and the road w...   Nov 9 2019, 04:21 PM
sixnotfour   Augustus Owsley Stanley III is rumored to have mad...   Nov 9 2019, 11:47 AM
settador   Augustus Owsley Stanley III is rumored to have ma...   Nov 10 2019, 11:00 AM
rgalla9146   So I have this '76 914-8 with an LS-1 convers...   Nov 9 2019, 12:32 PM
djway   Back in the day my lil Baja Bug shot up two monste...   Nov 10 2019, 01:28 AM
914bub   And if you do have a limited slip and you break em...   Nov 10 2019, 11:33 AM
drifter914   Thanks you guys for the interesting replys & S...   Aug 10 2020, 11:59 AM
rhodyguy   Then everything starts melting and Stairway to Hea...   Aug 10 2020, 12:08 PM
KELTY360   Then everything starts melting and Stairway to He...   Aug 10 2020, 01:20 PM
- Lo-Fi Version Time is now: 10th September 2026 - 05:12 AM
