| drifter914 |
Nov 8 2019, 10:03 AM
drifter914 ![]() ![]() Group: Members Posts: 50 Joined: 12-May 13 From: pearce, arizona 85625 Member No.: 15,863 Region Association: Southwest Region |
So I have this '76 914-8 with an LS-1 conversion & one day while pulling out of a graveled area I kicked it a bit & noticed leaving 2 ruts behind instead of the one I was used to in a previous 914.
So the other day when I had it up on jack stands I started it up, put it in 1st gear & let it idle while I got out to look... left rear wheel was turning fwd at a constant rate, while the right was also turning fwd, but at a slower rate. Could it be that I have some sort of limited slip arrangement here ? Transaxle is a modified 901 & has the numbers HA 22095 on the bottom of the case. Thanks for any info on this... Terry |
| rgalla9146 |
Nov 9 2019, 12:32 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,996 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
So I have this '76 914-8 with an LS-1 conversion & one day while pulling out of a graveled area I kicked it a bit & noticed leaving 2 ruts behind instead of the one I was used to in a previous 914. So the other day when I had it up on jack stands I started it up, put it in 1st gear & let it idle while I got out to look... left rear wheel was turning fwd at a constant rate, while the right was also turning fwd, but at a slower rate. Could it be that I have some sort of limited slip arrangement here ? Transaxle is a modified 901 & has the numbers HA 22095 on the bottom of the case. Thanks for any info on this... Terry a 914 trans with OEM LSD would have HB as a prefix....but many types are available for later install. your two wheel burnout is due to reduced traction and a straight start. |
drifter914 Is this LSD ? Nov 8 2019, 10:03 AM
mepstein Jack up the rear. Turn one wheel forward. If they ... Nov 8 2019, 10:13 AM
Retroracer
Jack up the rear. Turn one wheel forward. If they... Nov 8 2019, 01:54 PM
GregAmy The car that made these two equal-length tire mark... Nov 8 2019, 11:05 AM
burton73 My Cousin Vinny (5/5) Movie CLIP - Automotive Expe... Nov 8 2019, 02:50 PM
mepstein Sorry, meant to say if both turn the same directio... Nov 8 2019, 03:33 PM
drifter914
Sorry, meant to say if both turn the same directi... Nov 9 2019, 10:30 AM
Superhawk996
Sorry, meant to say if both turn the same direct... Nov 9 2019, 11:56 AM
settador Last time I had LSD
I saw colors and
the road wa... Nov 9 2019, 11:19 AM
GregAmy
Last time I had LSD
I saw colors and
the road w... Nov 9 2019, 04:21 PM
sixnotfour Augustus Owsley Stanley III is rumored to have mad... Nov 9 2019, 11:47 AM
settador
Augustus Owsley Stanley III is rumored to have ma... Nov 10 2019, 11:00 AM
djway Back in the day my lil Baja Bug shot up two monste... Nov 10 2019, 01:28 AM
914bub And if you do have a limited slip and you break em... Nov 10 2019, 11:33 AM
drifter914 Thanks you guys for the interesting replys & S... Aug 10 2020, 11:59 AM
rhodyguy Then everything starts melting and Stairway to Hea... Aug 10 2020, 12:08 PM
KELTY360
Then everything starts melting and Stairway to He... Aug 10 2020, 01:20 PM![]() ![]() |
Lo-Fi Version | Time is now: 10th September 2026 - 05:13 AM |
