| AKFish |
Nov 11 2019, 05:39 PM
Newbie ![]() Group: Members Posts: 29 Joined: 10-December 18 From: Nampa, Idaho Member No.: 22,714 Region Association: Rocky Mountains
HI there, my name is Dominic and I have an avid reader of this forum for nearly a year, now its time to get rolling on my project...
About this time last year, I purchased a 1973 914 2.0. The previous owners bought it as part of a bundle of 914's and only kept a couple. I have some documentation from when the car was first purchased, but the more recent owners have proven elusive. It was owned by a member here named "kurbfrog" but he/she has not responded to my contact attempts, so recent history is a bit murky. Sounds like the guy I really want to talk to, headed south of the border in a bit of a hurry. I acquired the car in a partially disassembled state. The engine, a 2.0 with it's original FI still attached, is out and pretty much everything is removed from the engine bay and the interior. Many of the removed parts are carefully bagged up and some even have labels. On the whole, the car is in pretty solid condition, however, there are some of the typical rust issues..... The engine shelf has been cut for A/C and there is rust in the hell hole and I can see rust developing in the outer long (I think that's what it is called). My reading here would suggest that there is a lot more than meets the eye. What I would really like to do is find out if the engine runs...and if so, just put the car back together and drive it for a while. I could decide after that, if a "rustoration" is right for me...I have zero background in fabrication/welding. Question: What are the MUST DO items to perform on the engine while it is out, to give me the best odds of getting the car going again? P.S. My car came with this 1975 Roller that is pretty well gutted. |
| barefoot |
Nov 11 2019, 07:47 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,553 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States
HI there, my name is Dominic and I have an avid reader of this forum for nearly a year, now its time to get rolling on my project.. Question: What are the MUST DO items to perform on the engine while it is out, to give me the best odds of getting the car going again? First see if the engine will turn over. you can use a screwdriver thru the access hole by the flywheel to slowly turn the flywheel, if it turns, then set up a battery and do a compression test, or better yet buy a cheap leakdown tester and check leakdown rates. If that passes, you can run the engine just setting on wood blocking by jurry rigging fuel supply (easier with carbs) |
| AKFish |
Nov 11 2019, 08:14 PM
HI there, my name is Dominic and I have an avid reader of this forum for nearly a year, now its time to get rolling on my project.. Question: What are the MUST DO items to perform on the engine while it is out, to give me the best odds of getting the car going again? First see if the engine will turn over. you can use a screwdriver thru the access hole by the flywheel to slowly turn the flywheel, if it turns, then set up a battery and do a compression test, or better yet buy a cheap leakdown tester and check leakdown rates. If that passes, you can run the engine just setting on wood blocking by jurry rigging fuel supply (easier with carbs) I removed spark plugs and turned the engine over by hand, replaced plugs and I can still turn over but with the resistance of compression. No audible scraping or crunching...oil appears to be new. Can the D-Jet FI be run with the engine out? Thanks very much. |
AKFish '73 914 2.0....what to do first? Nov 11 2019, 05:39 PM
AKFish The engine as I received it...
Nov 11 2019, 05:43 PM
AKFish The bad...
Nov 11 2019, 05:44 PM
AKFish Outer long?
Nov 11 2019, 05:46 PM
AKFish Cut out for A/C...
Nov 11 2019, 05:47 PM
AKFish This 1975 came as part of the package...its been h... Nov 11 2019, 05:58 PM
AKFish I included the VIN in the data base, but here it i... Nov 11 2019, 06:05 PM
SteveL Step one is to identify all rust and repair. Hell... Nov 11 2019, 06:41 PM
AKFish
Step one is to identify all rust and repair. Hel... Nov 11 2019, 07:24 PM
Mike Bellis
Oh boy...ok. 1. Buy welder. 2. Learn how to weld... Nov 12 2019, 09:37 PM
Superhawk996
:drooley: Very nice looking engine and tr... Nov 12 2019, 12:36 PM
914_7T3 Nice Project!
Several members including mysel... Nov 12 2019, 12:20 AM
AKFish
Nice Project!
Several members including myse... Nov 12 2019, 06:41 PM
914_7T3
[quote name='914_7T3' date='Nov 12 20... Nov 12 2019, 06:50 PM
AKFish Here's mine, lots more subcontract work and to... Nov 12 2019, 09:02 PM
jcd914 You can run the engine outside the car.
It is easi... Nov 12 2019, 12:29 AM
Tdskip Good morning and welcome.
In addition to what th... Nov 12 2019, 10:49 AM
sfrenck Consider buying a roller if you don't want to ... Nov 12 2019, 11:22 AM
dr914@autoatlanta.com very little rust in your car, and all of the repai... Nov 12 2019, 12:04 PM
bbrock Nice Car! Right year. Right engine. And righ... Nov 12 2019, 12:21 PM
Superhawk996
Honestly, what you've shown so far doesn... Nov 12 2019, 12:30 PM
bbrock
[quote name='bbrock' post='2761552' date='Nov 12 ... Nov 12 2019, 03:18 PM
AKFish
[quote name='bbrock' post='2761552' date='Nov 12... Nov 12 2019, 09:06 PM
Rand Don't put money into drivetrain unless you wan... Nov 12 2019, 12:33 PM
jmitro in my opinion doing metal fab and welding takes a ... Nov 12 2019, 01:29 PM
AKFish Ok dang it, I’ll have to figure out how to respo... Nov 12 2019, 07:50 PM
bbrock
Ok dang it, I’ll have to figure out how to resp... Nov 12 2019, 09:40 PM
AKFish @914_7T3 just comparing our VIN #’s. They were... Nov 13 2019, 06:07 PM
914_7T3
[b]@[url=http://www.914world.com/bbs2/index.php?s... Nov 13 2019, 11:38 PM
AKFish Drivers side jack post hole is paper thin and the ... Nov 23 2019, 08:43 PM
rhodyguy It's the work to be done before you start cutt... Nov 23 2019, 08:53 PM
AKFish
It's the work to be done before you start cut... Nov 23 2019, 10:06 PM
mepstein You will have to cut out all the rusty metal anywa... Nov 23 2019, 08:56 PM
AKFish
You can repair the car without a frame. Jack it u... Nov 23 2019, 10:03 PM
mepstein Hows the right rear suspension consoles? Water run... Nov 23 2019, 10:12 PM
AKFish
Hows the right rear suspension consoles? Water ru... Nov 23 2019, 10:32 PM
bbrock Well NOW you have a project. I agree with @mepst... Nov 23 2019, 11:31 PM
Superhawk996 One thing to keep in mind with respect to putting ... Nov 24 2019, 10:57 AM
AKFish OK, enough “analysis paralysis”! Bought a ... Dec 9 2019, 07:36 PM
AKFish Today I went digging around the jack post area....... Dec 9 2019, 07:45 PM
rjames
Today I went digging around the jack post area...... Dec 9 2019, 08:41 PM
AKFish
Today I went digging around the jack post area..... Dec 9 2019, 10:17 PM
rjames Yes. I was in a similar situation. The outer layer... Dec 9 2019, 11:50 PM
jmitro I removed part of the rear quarter panel to repair... Dec 9 2019, 09:32 PM
AKFish @jmitro your project is an impressive feat to be ... Dec 9 2019, 09:50 PM
dlee6204
Yes. I was in a similar situation. The outer laye... Dec 10 2019, 03:32 AM
bbrock On double-walled repairs, I took two approaches. ... Dec 10 2019, 08:22 AM
AKFish Well, its been a little over two years since I upd... Jan 29 2022, 08:58 PM![]() ![]() |
Lo-Fi Version | Time is now: 28th September 2026 - 01:59 PM |
